  • Replies 350
Ah yeah my bad :wavey:
i give you props for correcting yourself as i was going to post a screen shot of what i see in the forum. As skylinekiller wouldn't have the balls to acknowledge fault.
And there is no reason for me to register in that forum to
1) see the search function or
2) act like skylinekiller on here and bag the piss outta holden when i could have easily said FORD has won the Supercars 2 years in a row and the commentators keep commenting on Ambrose's FORD being the best designed car.
Does that make FORD better than Holden because Ambrose can get his to perform better than anyone else?
Oh and i had a scan through an old post of the GTR at Bathurst and its history etc etc and i read that Mark Skaife used to drive a GTR. I wonder if i should ask his opinion to compare a 1990 built GTR to a 1990 built v8 holden or Ford.
Oh 1 other thing can anyone explain to me why v8s Holdens need to have such a huge capacity 5.7L engine when a GTR needs a 2.6 to perform just as quick?
HOLDENS ARE CRAP WHY COMPARE TWO STANDARD CARS FOR?
YOU MUST ALREADY KNOW THAT JAPAN HAD TO RESTRICT THE POWER OUTPUT OF THE GTR TO SELL IT, AND AN UNDERSIZED EXHAUST CAM SHAFT JUST TO PASS EMISIONS JUST!
SO IM GOING TO INFORM YOU THAT THE GTR WAS DESIGHNED TO DO A JOB AND THAT WAS
TO SMASH ANY OTHER CAR IN A REAL CIRCUIT RACE.
WICH IT HAS PROVED WITH EEESE.
AND THE HSV WAS DESIGHNED TO CARRY A FAMILY FULL OF REDNECKS
WICH IT ALSO HAS PROVED WITH EASE. FAG
:upurs: :upurs:
:upurs:                :upurs:
:/:P
I was in a mates R33 GTST and we saw a torana doing a burout, he pulled up beside us at a set of lights and i comented saying "nice burnout", then the F*UCKING R*TARD in the passenger seat of the torana yells out "4WD are shit" and gives us the finger, LOL that just shows the intelligence of most dumb sh*t holden drivers!
I guess this is a bad time to let all you bitches know that we just finished our first combined event with the Commodore club down here. The guys in the other club were decent folk, just like our members. I think its about time patriots loosened their respective heads from their asses and accept that the opposition own cars that are good in their own right.
Because you Sir, Are an Idiot!!!!! No more- No less!!!
Next thread being started.....
Space shuttle Discovery with LS1 Edit Vs. Space shuttle Columbia with cat back exhaust and 5 psi boost increase
Get a life.
You Plank
Mike
you know what someone tells a joke and its funny, then your with that person again around a different people and they tell the same joke again?? well it aint funny no more you just want them to shut the f**k up.
well thats this thread!
it aint funny no more. let it quite while its ahead.
die mofo die
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
    • Yeah the rule of thumb with an LS is 7psi per 1000rpm. That is decidedly not enough at 6800rpm. I mainly looked for the scenarios where knock started to be picked up and it was later in the session when things were hotter, and oil was thinner, and the pressure was lower than it should be. (i.e very horrible). I am hoping with thicker oil (I was running Penrite ten tenths 10-40, the manual specifies 10-30) that does not leak that it's much improved at that time!!! I am using Project Mu Club Racer CR pads. I'm also using the Project Mu 335C fluid. The symptoms imply that it was fluid that boiled, but no bubbles seemed pretty weird to me when I bled it today. I want to try Castrol SRF as it has a much higher wet temp but, well, I have new Project Mu fluid lol... so I should at least use that. The pedal on track was really noticable. It went from basically normal feeling to instantly near-floor. The car did pull up as before, it was just very much nearly at the floor before the brakes engaged. At that point I pretty much decided the day was very done, it did *kinda* come back during that very slow cooldown lap into the pits. Felt perfectly fine driving home.
    • f**king around with the bro
