Massive Skyline Cruise 3 in HPI!!! or Mud is a Chump.
  • Replies 63
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
ChumpChump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
ChumpChump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
ChumpChump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
ChumpChump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
ChumpChump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
Chump
What are you trying to say col? :confused:
Well he sorta posted something that was already there.... So yeah his chumpiness was decided by the forums... Its important to keep his chumpiness a top priority...
You see
"I believe in an SAU that allows everyone in QLD pay out on someone i have never meet (MUD) and have great pride in doing it."
C yrus
H as
U nusually
M oronic
P rocedures
... for telling me my rhyme was bad form :cheers:
this is not a ...."...Cyrus is a Chump..." Thread, it reads, "Mud is a Chump"
game on
