For sale: PWR Barrel Cooler, 6"x10"
Item Condition: Brand-new never fitted.
Price and price conditions: Asking for $1450 for the whole kit
Extra Info: The cooler has been polished proffesionally, it was not done by PWR. It was purchased for my car but plans have changed. :P
It is all tig welded and has 15 fins per inch!
Extruded Tube and Fin Cooler!
Pictures:
Contact Details: Please reply here
Delivery & Conditions of Delivery: Pick up/Delivery/Mail
https://www.sau.com.au/forums/topic/65050-fs-pwr-w2a-intercooler/
  • 1 month later...
  • 1 month later...
This is awsome for Street, Circut, Drag and Dyno.
It is a much superior than the ghetto front mounts people use.
Water is has the highest KJ/Mol heat resitstance.
You can have constant temps with no heatsoak.
You get inlet temprtures a couple of degrees above ambient on day to day driving or if you add a cold box (which is what i am going to do) then you can put dry ice or conventional ice and run bellow ambient tempretures, imagine on a Dyno doing 2 degree inlet temp when everyone else is getting 40+ on a hot summers day!
Same applies for the drags.
The reason you don't see many of these around is that people are too scared to use them. The top drag racers and dyno queens use them. And after instalation they are the same price as a FMIC.
What you pay for the core and all the extras you save in pipe length when you come to do your plumbing .. and that meams less lag!
Thanks for the quick reply, Iam very very interested in this cooler, and I am going down to my local mechanic dude tomorrow to ask him possible positions to mount that barrell.
I was thinking, why dont Japanese Tuning houses make thier own water to air coolers if they are better?
The one in the picture below is off the PWR website.
The one in the bed is the actual cooler, its a pretty bad picture, qulaity wise.
The ends are on there But i can have them removed for anyone who wants that. The bends were done by PWR to suit an RX3 Drag car. But it was never fitted.
Cheers
Sam
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
