Looking at doing some sort of heat shielding for my 2 pods that are just sitting there sucking hot air at the moment but wondering what to do about getting some cold air into them afterwards.
My gtst was easy as it already had a nice 3" hole from factory right where I wanted it.
My question is it safe to cut a 3" or so hole right below were the pods are then I could do the induction easily, just ive heard something about how it makes all the support weaker on that side etc etc. It probably wont be so obvious just looking at it from the engine bay.
Only other option I can think of is the headlight replacement but I want it for street use so that would be no good.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/
It has the stock airbox, but who knows what in it or if the box is modified?
LW.
OK I'll go another route.
Stock air box, Piper cross panel filter, custom stainless pipe to replace stock rubber one between turbo/s and AFM.
maybe ask Sydney Kid the max power he has seen from that set up on a GTR.
Honestly, when I had my GTST (R32) and had a pod filter, the thing was only producing like 155rwkw and the engine bay was so hot, the intake temps were like in the 60's during sydney traffic.
so imagine the engine bay of a gtr with 2 turbo's producing obviously more power.
and 2 pods taking up the same room.
even hotter air there for sure.
the stock air box is good.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1222333
GTST: I am aware of Gary's view on Pipercross filters: in fact I will be putting one in the (stock) airbox of my R32 GT-R very shortly.
My point was more that although the Mines R34 may have the "stock airbox", for all we know its been completely changed on the inside. I'm not sure it makes a particularly good point of comparison given all the unknowns surrounding the car.
LW.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1222395
LW - I was just trying to make the point of the stock GTR air box with a panel filter is going to be a better option that PODS in the engine bay.
AND it is cheaper to buy a stock air box and new panel filter, than it is to buy an aftermarket heat shield/air box which probably still uses tha factory snorkel.. to shield off the dirty used pods that would have come with the car from japan.
you will be able to produce the same power (possibly more) if using stock turbo's and maybe even with after market turbo's..
the cost of buying a stock airbox and panel filter is going to be cheaper than buying a heat shield for sure. and give a better result.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1222437
To answer your original question I drilled a 3" hole below my rear pod. I don't see how it has any effect on the structural integrity on that side. I have two 3" flexible hoses in the front bar. One running through the hole to my rear pod, the other through a factory whole under the headlight to my front pod.
Hope that helps.
Gary.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1224680
theres a factory 3" hole under your front pod? ah thats right yours is 32 so probably different.
You reckon 1 3" hole would be enough for the 2 pods? dont really want to cut 2 holes. Might cut 1 hole and put a scoop intake on also (hope it doesnt look ricey :Oops: )
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1224876
The factory hole is under my headlight and was used for part of the air box setup that went to a resonator box. I thought the 33's would have had it too but I could be wrong. It is more like a rectangle hole next to the carbon canister. One big hole is probably enough though.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1225169
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
