Ok, did the usuall search thing. Came up with one topic that was pretty much useless in the general mantaince section. I think the topic would be better in this section as its a more performace/handlening related item.
Anyway, which diff oil do I use!? Even the mechanic doesnt really know as he has never come across a 2way before (more so he knows Im picky and wants to make sure what I want goes in)
Basically what Im worried about is the few people I have asked have susgested normal LSD oil, and I get this funny feeling that using that type of oil would not be too good for the diff.
Also, the diff tention settings (if the diff has them) how would you know how, and what you need to change, like is it an obvious thing, or do you need a 20 page instruction manual to work it out.
As always any help is greatly appreciated.
https://www.sau.com.au/forums/topic/65297-2-way-mech-diff-oil/
Just use a good quality mechanical LSD oil, hypoid GL5. If your planning on track work or other hard use, consider a synthetic. Personally I use Penrite oils.
For clutch pack LSD's and similar it's normal to measure the break-away torque. Basically one output shaft is held stationary and the torque required to get the other o/p shaft to move is measured using a torque wrench (and some form of adaptor). The measured torque is a measure of the amount of 'lock' in the centre before the wheels start to go their separate ways, as it were. Stock Nissan centres have a fairly low break away torque, in the region of 30ftlbs or so, but extra plates can be added to make the diff pretty much fully locked. This would be a pain for street driving tho. We aim for a break away torque in the rgion of 70-90ftlbs as a compromise for street and some track work.
Putting in extra plates requires dis-assembling the centre and should only be done by someone that knows what they're doing...
There are other types of LSD (eg Torsen), but I'd say the majority are variations on the clutch type, particularly with Nissan's
I used a Valvoline LSD oil when i changed mine,i think it was 85/120?? it was a while ago i changed it so couldnt be 100% on the grade.....
Would be very interested to see peoples opinions on this because since the change everythings working fine, but a little "clunkyer" when tuning at slow speeds....ie: U turns.... people often say to me 'whats wrong with your diff?", kinda hard to explane that its normal
Would be very interested to see peoples opinions on this because since the change everythings working fine, but a little "clunkyer" when tuning at slow speeds....ie: U turns.... people often say to me 'whats wrong with your diff?", kinda hard to explane that its normal:
Sounds like chatter. There's an additive you can get that helps overcome this problem, but of course there's no guarantee. I know that Penrite make one:
http://www.penrite.com.au/nextpage.php?nav...view.php&id=114
They also have a very helpful technical dept (...no I don't work for them :()
Well mine got changed with the stuff the mechanic had, seems a lot smoother already (mind you the stuff in there was black, and there seemed to be a rock *dunno but, could have been on the outside*)
It was valvoline stuff 90-something. But yeah, as I said, less cluncks, and a fair bit smoother.
This is what we use;
Engine oil = Castrol Formula R Synthetic 10W60 or 0W40.
Brake Fluid = Castrol SRF
4WD Transfer = Castrol Transmax Z
Auto Gearbox= Castrol Transmax Z
Radiator = Castrol Anit-Freeze Anti-Boil
Diffs = Castrol SAF-XA 75W140
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
