Well till next time lads, look forward to whoring with you, cometh one whore and then cometh the other :thankyou:
It looks like im going to have to kick it a nickle though as the rest of the bumbs from the Apple Isle seems as usefull as a **** flavoured lollypop :jester:
Good to see you have masterd the art of whoring.. too bad you dont seem to be on when im around LoL :)
Just have to read the user name champ :innocent:
The only down side to shift work is the hours that you work compared to everyone else. At times it can really drive you crazy :uh-huh:
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
