well normaly I can drink on fridays at work, but ther was no beer thistime ;)
Poor excuse that.
There is always time for a beer run sl!m <_<
You will have to try harder next friday
or better still put in a double effort when i come over :(
Cheers B
well i didn't even make it near a geek machine all weekend... mainly cos i was drinking........
boy i was punished for it today aswell......
i didn't have a choice as i been busy planning my trip and was getting all the info i could while the weather was shite house......
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
