you need to buy your woman a razor.
went to get one yesterday but your Mrs was there and bought out the store!!!!
She was going to ask her for her autograph cause she thought it was chewy from Star Wars :lol:
I can cash any cheque my ass writes,...
Just not in a regular bank... :(
YEAH i have the same problem as well.
Always get thrown out of the bank when i flash my arse, dont know why <_<
I didn't deliberately post it that way...... really.
:) i belive ya
i like that this thread was started by a qld whore
Thats cause Prank wont make one of us "TASSIES" a mod for this section.
Thats one of the main reason's peeps wont post.
No offence to Slaz but he doens't know any of us, we dont know him and i dont think i have seen any of his moderating duties been done in a while???
Who gives a flying fubar who started it, there are 2-3 Tassie members that come in here from time to time and other than that its whored by peeps from all over Australia that dont have a life or anything else better to do ;)
(last bit os a joke :huh: )
Cheers B
Who gives a flying fubar who started it, there are 2-3 Tassie members that come in here from time to time and other than that its whored by peeps from all over Australia that dont have a life or anything else better to do :huh:
(last bit os a joke :) )
Cheers B
lol ... nice call ;)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
