Dr Pepper!!!!!!!!!!!1
argh I havent had some for so long.. cant wait till I go overseas next month.. going to eat all the american food I miss so much
I buy it a carton of it every couple of weeks.
Man im addicted to that stuff :P
f**k f**k f**k f**k
I have to check and see if I got parked in by my boss in the carpark..
i have to go have a passport interview at 3pm and I wont be able to make it argh f**k
What does your boss drive???
