hi.
This is Joshwa
akaNismo Boy Joshwa's Myspace
Now my friend Joshwa wants his face and emo haircut to dominate Sau. as a joke between us Queenlanders. now joshwa is aware of this and actually is interested in this lil project we have his full permission. so if you want to be part of something that will hope fully catch on please copy joshwa into ur signature or avatar.
thanks
Mark
Copy this code into your Signature to have joshwa's face gracing SAU. (just delete the "*" when you put it in ur signature)
[img*]http://www.skylinesaustralia.com/forums/uploads/post-21318-1191557092_thumb.jpg[/img]
My Hero Joshwa
  • 3 weeks later...
Not bad, better than last year.. gets f**king itchy though
HA HA tell me about it, i cheated last year and shaved a couple of times :worship:
Still had a better mo than half my mates :laughing-smiley-014:
haha, yeah some of the guys at work have some pretty.. pathetic.. attempts
Everyone has started calling me choppa, or uncle chop chop etc lol
even ppl in my movember thread have started so I guess I must look like the sonofabish
  • 3 weeks later...
herooo... STAGEA onwer from townsville here. I am driving down for a wedding circa new years (in the bridal party and the stagea is going to be the car for the bridesmaids - the blokes have the 34) and I have two questions...
1: should i be worried about QLD legal mods down there (boost tap, secured pod filter (not enclosed), zaust and lowered or should i be fine?
2. does anybody have wheelstands that i can borrow whilst i am down there. I won't actually have the lowered springs until just before i leave so i am driving down with my stock suspension in most probably... lowering it for the wedding whilst i am down there, and then driving back up. I have everything else i need (spring clamps, ratchet, breakerbar, etc etc)... unless you have a hydraulic jack too which would make life a little easier than using that bloody mechanical thing.
You shouldn't have any problems down here when it comes to your mods, the police re pretty easy going so if your doing the right thing they generally wont bother you.
As for wheel stands i have a set and your more than welcome to them, depending on what day your doing it i might be able to line up a hoist for you :P
Cheers Ben
  • 3 weeks later...
Hey there,
I too have a set of axle stands, a flat driveway, AND A STAGEA!!!!!! More than welcome to swing past and meet up if you want.
Where's this wedding you have to go to? Hobart I'm guessing. Can you name locations?
Cheers, Greg.
    • @GTSBoy are your spam bot senses tingling too?
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
