  • 1 month later...
  • 4 months later...
Hi Guys!!
In Tassie this week as navigating in a Dirt Rally on Saturday "Styx Valley Rally" ..First time so scary as hell! :D
Just wanted to say you guys live in a gorgeous place..I have been staying up in Burnie this week place it's amazing, only let down is the lack of vodafone phone coverage LOL :laugh:
Heading down to Hobart today so cant wait to see the rest of Tas :D Will be out in Hobart Saturday night..check out the night life and have some fun after my massive day Naving. If anyone is out and about and wants to meet up My Number is 0404042532 would be cool to catch up with some Tassie SAUers! :)
Seen about 4 x GTR's so far around Burnie :) a
Jess xx
  • 1 month later...
  • 3 weeks later...
hey folks!
Im in the process of buying some wheels off a bloke called scott Chambers. (scottys13 on ns.com)
Am organising it all through NS.COM. but the site has been down the last few days, so i cant contact him.
If anybody knows him can u please please get him to call me or pm me through here.
my number is 0425 759 644.
ANy help would be excellent!!
  • 3 weeks later...
Domain hillclimb vids :P
3rd run i did when it was fully dry
2nd run crash, start corners were nice and dry , came a little too hot into water tower corner and car slid to the lift into the bank. only damage was back side skirt mount dislodged.
Better late than never Ian, besides you should get used to being late now you own a SR :)
oh low blow haha yeah ill take that on the chin not a fan of the old SR :)
Edited by ian_and1
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
