I have PMed the 2 of you regarding a possible group buy. Please get back to me asap. Anyone else wants to join in this group buy?
btw the drift wing is the wing in the picture below :
I called Jetspeed at Moorebank NSW this morning and they said they usually sell the R33 stealth wing for $250. But if I can get hold of 3 or more people, They will give a 20% discount.
So far I have 3 interested parties :
1) Zigengt (myself)
2) Mr_G
3) Pavel
Please contact me if interested. If we can get more orders, they might give bigger discounts.
I have also started a thread in the group buy section regarding this group buy
Hi There...
since they are in sydney, would they do the paint matching and install ??
:rofl:
you would have to organise that separately through jetscolour which is behind them, but separate!
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
