After the instakllation of the GT-RS turbo i have noticed some pinging (the dash warning light is coming up when giving it a bit). I took it back for a re-tune, dropped the boost back to 1.2 bar and took the timing back a few degrees and richened the mixtures to i think 12.5 and there is still pinging. I raced at the creek last night and it pinged in 2nd gear at 4500 rpm to redline then the other gears it was fine. The tuner said it is that the engine is getting to hot?? any ideas?
https://www.sau.com.au/forums/topic/65677-pinging/
I have done everything regarding fuel system. injectors, pumps 044 and standard, sard fuel reg, (filters, plugs, all oils, and gaskets were replaced when turbo was fitted). Have a Power FC for management. Dont have cams, plenum or anything like that. It does not ping when i put the boost to 14psi but when it goes up from that it begins, also you cant hear the pinging so its not bad at all just the slightest knock.
https://www.sau.com.au/forums/topic/65677-pinging/#findComment-1227476
Not having a HC doesn't help much !
What fuel are you running, If you'r running down the strip i'd use BP ultimate + Nulon Octane booster, this stop detination :( - Could be a bad batch of fuel.
Other wise its down to the tune, you said 2nd gear... get you tuner to do the map tracer for second gear, find the detination points and pull 1º - 2º of timing & add more fuel in thoes load points.
:D
Jun
https://www.sau.com.au/forums/topic/65677-pinging/#findComment-1228469
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
    • Yeah it is wild how much wider the Yokohama A050 in 255/40R17  vs Yokohama AD09 in 255/40R17 sits on the 17x9 +22 considering its even from the same brand and adjacent product family
    • Would love to see some examples of WMI making the same as E85. Only thing I've ever found is this one.  Which suggests WMI is not worth much at all.
