Have you ever heard that cross drilled brake rotors crack? Here's the story...
Hi all, after speaking with DBA (as I need new rotors) I thought I'd ask why cross drilled rotors are only recommended for "street use" because I know a lot of people wonder why this is the case and what will suite them. The E-mail reply was as follows...
Question -
"Just one more question. I know that cross drilled are not recommend for track use, is this because of the weakening effect on the rotors or is it more a liability thing? I have heard of cracking of the discs but realistically what sort of braking are you going to have to be doing to cause this?"
Reply -
"Adam,
the reason why we don't recommend cross drilled rotors for racing or track work is due to the following:
The disc rotor face surface area is reduced due to the holes and as a result this face heats up faster under braking.
Once you release the brakes the rotors cool very quickly due to the holes.
Due to this rapid heating and cooling of the rotor face it is possible for the rotor face to sustain what is known as heat shock.
Because the rotor is unable to heat soak and dissipate heat evenly the face of the rotor can develop cracks around the holes.
The use of slotted rotors allows the disc to heat soak and cool more evenly so the rotor is less prone to suffering from heat shock.
Heat shock can be evident in cross drilled rotors even when used by an extremely energetic driver on the street. If the drivers driving style is fast with rapid jabbing of the brakes and exallerator pedals he/she will be more likely to have problems with cross drilled rotors. Due to this reason we recommend the fitting of cross drilled rotors for looks only and improved braking performance under normal driving conditions.
I hope this answers your question, but if you have any further queries please feel free to email me.
Kind Regards,
Aaron Franklin
Technical Sales Advisor
Disc Brakes Australia Pty Ltd"
Thought this might be some helpfull info!
so is it safe to assume from that that cross drilled AND slotted discs will be less prone to this?
"The use of slotted rotors allows the disc to heat soak and cool more evenly so the rotor is less prone to suffering from heat shock"
The cracks would still form around the cross drilled holes inark beacuse the change in temp would still be significant. The only way to go on the track is slotted. Do they make 5000 series for the 34 yet adz?
I failed my RWC for the first time because I had drilled rotors with 1cm - 2cm cracks on each hole nearest the edge of the rotor... they looked sweet but the funny thing was I passed my Engineerring Cert. but not the RWC.
From what I've heard the DBA rotors were drilled after they were fabricated? While the Porsche and other high-end rotors had the holes cast from factory?
Drilling post-fabrication gives less structural integrity doesn't it?
I could be wrong though..
Because they aren't $200 rotors like DBA are...
HAHA good point.
so in other words his statement is only relative to DBA rotors... not in general
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
