Never inject water or anything post throttle body unless you're doing direct port injection...
There is heaps of information on this on the internet, I have a CAPA based system on my shelf in my shed, not going to fit it to my R, probably a bunky. The thing is always that the volume that you displace by the water needs to be taken into account by adding more fuel. Another thing to note is that just injecting water will actually make you lose power, unless you use extra advance or boost..
Research.. Like I said, heaps of information on this on the net.. While you're at it, look into Toluene addition to your fuel, it is by far a better option, but once again, you must run extra advance or boost to gain any increase in torque/power..
http://www.designengineering.com/products.....asp?m=sc&cid=1
Check out that link. Its a system that uses Co2 as a cooling medium. Basically whats inside a fire extinguisher. Only costs about $20 to fill the bottle and its not flammable.
A friend has purchased both the intercooler element and the bulb for inside the intake. Will have results when its installed.
Looks very interesting.
well i think the water spray onto the intercooler is a good thing. But am 100% against water injection, true it will let you run higher boost with out pinging but it doesnt make any power its self where as methonal would. even a methonal water mix is better. and iv always sprayed after the turbo b4 the tb.
Spraying water before the turbo is soo wrong, water forms droplets that are as sharp as diamonds, great if you want to grind down your compressor wheel slowly, but that is your choice to make..
The best Water/Methanol mix is 50/50, I used to run a water/methanol mix when I was running in engines to keep the intake charge as cool as possible, used to remove it once run in and only ever refit if I wanted to get some extra advance..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
