  • Replies 473
/me bitch slaps Moanie upside down  :headspin:
ummm.....okaayy then...
see look what you done mike...you get strange guys who have no fu(ken idea who mona is wanting to bitch slap her......
ITS ALL YOUR FAULT MIKE !!
:rofl:
doodz: Im not just saying this cause mona is a girl (well most days she is :)) but you should talk to people on the forums and get to know them a little before making comments like that about ANYONE...guy or girl.
Yeah,
Only I can Jaw off like that..... And only because I am in QLD at the Moment.....I would't dare do it in front of Mona, She would Kick my A$$ like a cheap drunk!!!
Mike
:rofl:
exactly
get to know her then talk
/me bitch slaps moaner upside tha head
what is it with ppl getting drunk and saying somthing on sau then comming back and saying sorry cos they wernt really drunk, but realised that they sounded like a complete ass!!
btw.. /me slaps moonie upside the head wit a side of BEEF!
hmmmm me think what else we can use to slap moaner with
    • My thought is if you were just moving it forward and the upstream geometry remained the same, then no difference at all. But because the current one has the filter direct into the AFM inlet, you effectively have the best chance of a completely symmetric air flow profile upstream, and in, the AFM, whilst the aftermarket inlet thingo has a (small, to be sure) bend between the filter and the AFM. That would bias the flow to the outside of the bend (downstream of the bend) which might well reduce the size of the signal seen by the AFM, for the same total flow rate. Having said that: If you're proposing to make your inlet look like a hybrid of your existing one and the aftermarket one, such that there is no bend where the filter is clamped on... then I say it will be just fine. If there is going to be such a bend, then, if you can align the insertion of the AFM blade such that it is at right angles to the plane of the bend, then there is a better than even chance that the centreline velocity where the blade is will remain more or less the same, and the velocity will just be a little faster to the outside of that, and just a little slower to the inside. **This is not professional investment advice and you should consult a suitably qualified ouija board, tea leaves or the intestines of a goat for more accurate prognostication.
    • Hi Tao, Thanks for your reply.  It's been a while and I managed to get the valve stem seals replaced with the head on the car.  Unfortunately this didn't solve my issue, the car still smokes a lot after idling (to be honest during idle you can see a bit of blue smoke from the exhaust), same after deceleration. I will try disconnecting the valve cover breathers, do I leave the PCV valve in? By engine oil drain pipe, do you mean the turbo oil drain?
    • What about if you just give it direct 12v and earth?
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
