Hi everyone,
I recently bought an R33 GTS that came with an 'electronic spoiler' that activates from the dash with two buttons & 'spoiler up' & ' 'down' written on them, that lowers part of the front bumper (I'm guessing to help add to the downforce?) and for some reason only lowers when I'm not in gear (It automatically goes back up when you get into gear) or sometimes it won't lower at all.
I'm not sure if all R33s have this or not, so my question is whether anyone else knows what I'm talking about & why it will only lower when I'm not driving the car
I'm very confused with this thing so any feedback is much appreciated
https://www.sau.com.au/forums/topic/66288-electronic-spoiler-for-r33/
Im guessing you've got a GT Auto Spoiler, i got one to, on my R32. The spoiler will only come down when your not in gear and your hand brake is up (i'm guessing this is so you can wash it when your car is parked). The only other time the spoiler will come down is once you have reached and gone over 70km/h (listen for a electric motor sound soon as you hit 70km/h and thats the spoiler coming down), it will automaticly come back up once you have slowed down to 50km/h or slower. You can lock the spoiler so it doesn't come down by pushing the 'spoiler up' button and it will not come down automaticly any more and the button will stay stuck in, if you push the button again it will pop out again and go into auto mode but if your going over 70km/h and you just disengaged the lock mode, to put it back down you have to push the 'spoiler down' button. Turn your radio off and listen to the spoiler activating and deactivating by going over 70km/h and then slowing down to under 50km/h, its pretty cool
Hope that explains your question :)
Hope that explains your question  :P
Alright! Thanx for the explanation man real helpful. just anotha question... Is it for added downforce while driving like I think it is or is it for sumthin else? thanx again man
Yeah i think its for extra down force which gives you better handling and stability at higher speeds. I remember watching the Porsche Carrera Cup racing on tv a while ago and they reported that the lip on those cars give them up to 30% better handling apparently at high speeds and whilst they corner. The GT Auto Spoiler also looks good when it comes down watch for the amazement on people’s faces when they see it come down :).
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
