  • Replies 50
hey fane, marc got stickered in his mums line last night, too low, suspension too hard rice and sau stickers on side windows, loose wire in car and bleed valve, [what a joke] it was on uneven ground and was about 98-99mm clearance, in our garage level ground we have 120mm, when we got home i rang the police station and spoke to the guy in charge [night shift] and he said lodge a formal complaint as he,s getting a lot of phone call about stupid defects lateley
https://www.sau.com.au/forums/topic/66374-mandurah-cruize/#findComment-1238152
Lodge the complaint -- even if just for the satifaction that it will stuff him around as much as he is stuffing you around
https://www.sau.com.au/forums/topic/66374-mandurah-cruize/#findComment-1239125
yeh chris i have been real lucky lately... they haev always been going the wrong way with too much traffic to get me.... but they stair and they try and chase...
i am scared to drive to tell you the truth...
but as for the cruise as long as we get away from mandurah asap i'll come for a drive :rofl: ummm i think about 6:00pm leave would be good get a bit of light and dark...
ps. mandurah bus charters were good to me chris
https://www.sau.com.au/forums/topic/66374-mandurah-cruize/#findComment-1240652
stick it to da man chris
i must be the luckiest barge owner in mandurah they never even look at me twice ( touch wood)
fridy an saturdy nites is always good for cruises but hey ive got such a roaring social life that im available most all weeknites
https://www.sau.com.au/forums/topic/66374-mandurah-cruize/#findComment-1243250
    • bumping this post as im still having dramas, my fuel pick up is sitting on the bottom of the tank, my pump gets a constant 13 volts through a relay, my fuel pressure holds consistently without fluttering or dropping, yet as soon as im near half a tank of fuel my car starts fuel starving and leaning out, it cant be due to g force as it never pulls hard enough before it starts breaking up, any help would be much appreciated
    • Just a thought, was that car and auto at any point of its life? If so, maybe whoever bridged the inhibitor switch/circuit did a not so good job.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
