my head unit wont fire up. I checked the fuses, there fine. Pulled the unit out and reconnected it and nothing, so i thought maybe the unit may of had it...
ripped the headunit out of the mrs' car and still no fire. Also my little clock on the dash isnt working either??? everything else on the dash worx tho
https://www.sau.com.au/forums/topic/66380-dead-head-unit/
i bought a multi meter thingy today too see if there was any current going into the ignition and power wires for my headunit and it showed no charge for all the wires behind the headunit. I checked the fuses and they all seem ok.
How can i run my headunit so it has power but turns off when i turn the car off?
https://www.sau.com.au/forums/topic/66380-dead-head-unit/#findComment-1237712
Dude you have to make sure that have 3 wires from the head unit:
+Constant (Norm. yellow or orange)
+Acc (Norm. Red)
-Negitive (Norm. Black)
but you also have to have them from the loom of your car behind the head unit.
if you have a multimeter it is easy, always keep the -Negitive prong (lead) of the multimeter on some part of the chasis of the car and then test with the +Red prong (lead)
when the ign is off you will fine one of the wires will always have a voltage (12v) that will be your Constant (Yellow or orange)
then you have you try differant wires whilst turning the ing on and of to find the ACC wire in the loom.
meh if you can undestand that go here: The12Volt.com
https://www.sau.com.au/forums/topic/66380-dead-head-unit/#findComment-1240608
+Acc (Norm. Red)
if u get this the wrong way around then your memory wont stay in your headunit and the cd will begin form the beginning eachtime u turn ignition on.
are your parkers/brake lights working?? if so then uve connected the ground to the parkers instead of ground (i learnt this the hard way)
if your clocks not working then u must've blown a fuse... i think the parkers fuse is in the engine bay... but the clock fuse is in the car.
https://www.sau.com.au/forums/topic/66380-dead-head-unit/#findComment-1240638
I worked in a Car stereo shop for about 3 + years and It sounds like a fuse is blown.. I know you said you checked them but Id check them again.
80% of the time if your clock goes and your radio then they are on the same line.. Check if your interior light is working aswell.
Just my 2c Worth.
Cheers :headspin:
https://www.sau.com.au/forums/topic/66380-dead-head-unit/#findComment-1240970
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
