Hi guys, I have had an ever increasing number of people ask me about tuning their car without going to a dyno. They may live too far away, not have the budget or they simply may want to do it themselves. I have accumulated a few A/F ratio meters over time. I thought to help guys out, I might rent a couple of them out. They are not too expensive to buy, but the maintenance can be relatively high, you have to clean the lambda sensor and perform calibration regularly.
So......
How many would be interested in renting one for a week for say $100? That would cover maintenance and repairs etc. What you would get is;
*a wide band lambda sensor
*long lead to reach to the tail pipe
*a clamp for holding the lambda sensor in the tail pipe
*a meter and controller with sensor preheating for accuracy
*a mount and vacuum cup for attaching the display to the windscreen
*a cigarette lighter power plug & supply
*a full set of intructions
*a laptop interface and logging software to load (not necessary for tuning)
*all mailed out to you in an aluminium case
What you don't get;
*you are doing the tuning, if you damage your engine it's your problem
*if you get busted breaking the road rules, it's your problem
*I don't have time for dial up support, maybe email would be OK though
*insurance, if you break it or loose it, you pay for it
*a lap top, you supply your own, if you want to do logging
*credit, you pay up front and there will be a deposit (not sure how much yet)
*freight, you have to pay both ways, it's light, so $10 should cover almost anywhere in Oz
*instant supply, I only have 2 suitable units and I don't want to buy more. So you may have to wait until one becomes available
*to use leaded fuel, it must be unleaded
* to send it back dirty and greasy, clean it please
*your deposit refunded until it is received in good condition
This is a survey for me to judge the response, so post away. If I get enough interest I will be ready to go in about 3 weeks, as I would have to clean, service and calibrate the 2 units.
:D
You never cease to amaze me Sydney Kid in that you are allways prepared to go out of your way to help others, you are or should be made a legend.
When I have all my stuff up and ready to go I would love to take you up on your offer and $100 sounds like a good deal.
It would also give me a chance to callibrate my new digital fuel mixture meter gauge from silicone chip to see if it can be made accurate enough.
Thanks again I allready owe you one for bringing the other silicone chip products to us although I haven't fit mine yet.
Thank You :D:)
Gary
I've been spending WAY too much time learning at the HPTuners website so I can help out a GENIII boat anchor Commodore driver.
This is exactly what I need to start applying what I've learnt. Thanks for taking out the hunting for meters.
Adrian
Sounds like a great idea, out of interest what sensors are you using? Im at a bosch distrubutor so if you want some pricing on some bosch widebands...
The wide-band O2 sensor I would use for this is the Bosch LSU4.2 5-wire. It is easy to calibrate, warms up pretty quick and is fairly stable. So it is easy for novices to use, which is more import than getting 0.1% more accuracy or super fast response. Road tuning is not as demanding on those parameters as dyno tuning, ie; you have time.
They cost $US79 plus ~$A10 freight, no duty (US free trade agreement) and generally don't get GST'd. I haven't priced one locally for a couple of years, they were more than triple that when I last checked. What do they go for now?
:rofl:
:rofl:
Sounds good SK, I think it'd be a good thing to rent this equipment for those wanting to tune at home.
But I'd like to buy one of these sensors myself, I have been looking around but they seemed pretty pricey, at least when I was looking a few months back. Are you selling any, or able to get any for a reasonable price, as I'd be interested in getting one.
*keeps an eye on this thread* :)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
    • OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
