half way along the engine, drivers side half way down the block. Right next to the oil filter. Have fun, they are tight buggers. You might have to get a spanner in from underneath to get it loose. Sometimes you can crack them with your hand but I doubt you will.
https://www.sau.com.au/forums/topic/66584-urgent-help/#findComment-1243315
