So just wondering when it comes to everyone's cars, did you import and comply yourself, go through a importer or buy it from an existing owner??? I would love to get another turbo as they are alot of fun but at the end of the day i want something different from all the other skyline owners. Dont get me wrong and im not having a go at any of you at all, but i guess i like to be more of an indiviual
https://www.sau.com.au/forums/topic/66978-importedalready-here/
  • Replies 101
The my g/f's 300ZX, my GTR and my soon to arrive MR2 GT, I bought thru Prestige Motorsport and have done all the compliance myself.... everything was pretty easy, but it would be far easier if you don't have contacts to just buy something already here.
The clear short fall of buying sight unseen is that you don't really know what your buying until it arrvies, PM's inspect reports are pretty close, but in the case of the GTR they didn't know that the turbos had sht themselfs.... a costly couple of components if unlike me you didn't already have some spares waiting.
Compliance costs are generally around $1k extra for 4 new belts etc etc, plus rego, plus a service, plus a good cut and polish and maybe some bodywork, new stereo and maybe tyres, pads and rotors.... by this time your fast approaching the same price as an import dealer car that you get a warranty with.
brought mine local.
GMB, I still think skylines are bloody rare down here when you compare to other makes and models. I'm lucky to pass maybe 5 in a week and they are always the same ones.
I hardly see any at all. You make it sound like they're everywhere.
I think that skylines are still a pretty special car to have down here. Although after reading http://www.skylinesaustralia.com/forums/sh...53&page=1&pp=25 I could be tempted into getting a strawberry face sil80. yum!
brought mine local.
I wouldn't go as far as saying rare JaFF, hit up Kingston Beach on a good weekend mate and you will see 5 or 6 there alone. Im not saying that there as common as Fords or Holdens but it seems there growning in numbers these days. Compared to when i built my first turbo car not many on the roads then. One of these days i will have something for fun again, who knows what it will be??? If i see a bargain import then someone might be able to twist my arm :rant:
so how many skylines would you guess to be in the state?
seeings as there is about 300,000 cars in tas, probably well under 100 skylines. seems pretty rare to me.
You would be suprised how many there are. I can name over 10 straight off the bat and that doesn't include peeps i know that have a race/track car skyline. Im not saying there everywhere im just saying that go back a few years ago and you were lucky to see the occassional import on Tassie roads but these days it seems like every 4th car i see of late is an import of some kind. I dont care what other people's opinions are on other cars or what the like, all im saying is that import cars in general and A LOT of skylines are getting around on Tassie roads and i was wondering if they imported and prepped or bought direct???
No, Launceston, I'm not the guy at perth with the Supras!
You private or sell on behalf of the public??? What can you get in the way of cars and are your avenues limited at all in what availiblity you can look at???
Only private, have a 55000km GTS4 R32 on the way soon, and also a super neat standard R32 GTSt in rare factory green following that.
Sounds cool let me know when it comes in as i would like a look at it, im in the market for a gts-t. looking at one at the mo wit a wide body kit and some extra additions but not sure if the $$$ come in time???
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
