ummm...
-Forged and Polished Pistons
so the engine has been rebuilt?
when?
and
-0-400 10.78 secs (As quoted by me)(With UNICHIP)
that was a joke right?
do you have any actualy figures?
what power are you making with the unichip?
-Rego till Late Feb 2005
It's currently March 14, 2005... did you mean 2006 or is the car out of rego?
thanks.
i am pretty interested but i live in brisbane and work full time. you got pictures of it? whats the deal with the rego? (also think that 1/4 mile is a bit optimistic)
without a doubt this car is at a great price but i think you should revise your time predictions...its obvious that a 10sec time is out of reach unless there are some other SEVERE and extensive modifications you havent mentioned.
    • Great work! Thanks for documenting the process.
    • How would you even adjust the clutch if the pedal already has the correct free play? The operating cylinder has no adjustment in mounting position or rod length. On pull style clutches there is also no ability to adjust the bearing carrier. Push type I can see how adjusting the carrier height makes it all work.   If this is the twin plate clutch did you verify that your friction disks were oriented correctly? It's not mentioned in the directions at all you just have to notice that one side the friction disks have a part number on the hub fingers and a subtle coning to those fingers. Another thing that I noticed was if you put the friction disks in backwards the pressure plate fingers will not be even and flat when the clutch is installed.
    • yeah, mechanically, it is probably do-able, off the top of my head, there would be the transfer case, which I believe will bolt up to the rear of the RWD transmission, the shorter rear tail shaft. A front drive shaft, front diff, engine upper sump, front drive shafts, front hubs and front AWD struts (they are shaped around the front drive shafts), LCAs (at the very least from the front suspension) oil cooler.  You might want the rear diff from an AWD too, so you can be certain the front and rear diff rations are identical.  Who knows what brackets and mounts you might need.  So a whole doner car might be the best option if you need to maintain RHD. Then actually making it work, that would be a whole different story.
    • Take the fall as a warning sign for future endeavours  Stay safe mate
