Hi all,
I was just wondering if anyone could help me out here. My problem is that the HICAS light, lights up when I drive after a certain period. There seems to be no problem with the car but i just want to know why it is doing this and whether there is a problem.
Oh the car is a R32 1989 GTS-t.
Any answers would be great.
Cheers
https://www.sau.com.au/forums/topic/67826-hicas/
Check fluid levels including the one in the boot.
For the 314,468th time, the one in the boot is for ATTESSA, which only exists on AWD Skylines. The HICAS light on a R32 generally comes on when the P/S fluid gets a bit low.
https://www.sau.com.au/forums/topic/67826-hicas/#findComment-1257892
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
