well i was on my way today after 3 months of having my car off the road due to importing it to finally getting rego for the car.
come inspection day and i have all my papers and everything. inspection is done and then they decided to reject my rego for three things
1. momo steering wheel
2. hks bov
3. pod
now i have to start from square one and get all my papers re-issued :hellpisd:
if any1 can help me with these items it would be really appriciated if you could help me out. i have an r32 gtst
thx
p.s vicroads fully sussed me out, and treated me like a criminal ... bastards....
https://www.sau.com.au/forums/topic/68199-rejected-rego-need-help/
The Momo wheel should be ok, if it has the appropriate sticker on the back (like a price tag sticker with an approval number on it). The filter & BOV are technically modifications under ADR27C which makes them unlawful.
Sorry to hear about the mess mate. Can't help with any shops to help you out but I can comment on the legalities of the items they picked you up on.....
1. Any steering wheel that replaces the stock item must not be more than 1 inch (25mm) smaller than the original (not sure of EXACT size difference but the info shouldn't be too hard to track down) Also if the original has a padded center (which the std R32 one has) the replacement must also have one - same with an airbag.
2. Any bov that replaces the stock one MUST BE plumb-back type. Any venting to atmos isn't allowed.
3.Only ONE intake mod is allowed. ie if you have a FMI and a POD then you would have to remove one or the other. You are allowed a POD if you don't have an FMI.....
4.Apparently all Oz drivers have difficulty remembering the H pattern of a std gearbox and therefore all cars on ozzie road must display the 'H' pattern somewhere on the gearshift or surrounds. Now this is one of the stupidest rules I have come across however a simple sticker with the H pattern and gear No's on it stuck to the surround of the gearbox with solve the problem.
Anyway hope the info helps and you get your car on the road.....
thx for the info mate
i told the inspector that i was allowed the pod filter because i didnt have a cooler... he still wanted to see a box around it ............................. ..................................................................... i hate him
can some1 give me like evidence that im allowed a pod filter with no box? i really cbf getting a stock airbox
hmmmm I can tell you 110% that an uncovered POD with NO OTHER mod to the intake system is legal....if in doubt call the EPA for a ruling. The inspector (like 1/2 of them out there) doesn't seem to know a whole lot about cars/skylines and the ADRs. Maybe get the EPA to send a faxed copy of the ruling that you could show the vicroads inspector???
oh shit, im going to the dandenong office on thursday to get my gtr registered, i still have the pods on mine as well. i thought all they looked at was the VIN and engine number and u r outta there. does anyone have a spare air box lying around that i could use for the day?? which office would be the best to go to guys?? thanks heeps
pretty sure oiled types are illegal if not covered also...
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
    • yeah I was shocked when I checked my spare OEM on and as below that's how they come from Nissan. (side interesting note new NEO gearbox and replacement park lack the brass bush on the tips and its just all alloy) unsure about damage to the box currently back at 1110 to be pulled down/inspected and selector fork replaced as he built it previously and given the never before seen failure on his billet forks he is replacing it under warranty. He said he has used always OEM the keyway tab without issue for years so it could be an unlucky coincidence. I did talk to him about the sharp corners and stress concentration too. Re: hard shifts i got 7+ years out of the OEM one and the fork itself failed not the keyway. so could be bad luck as I said or an age thing + heat cycles in box and during fabrication of billet?
