Guys, I recently had my R33 broken into at a shopping centre carpark and almost had it stolen, they got as far as the key barrel so another 2 minutes and I swear it would've been gone! ....Just to let you guys know how they got in.
They struck the anti-carjack button (located on the drivers door) for the passenger door with a long object which they managed to wedge through the top of the drivers door/glass. It's obvious that they've done this before 'cause there was minimal damage to the car.
Either way. I think disabling this switch is a good idea.
https://www.sau.com.au/forums/topic/68338-dont-wanna-get-ya-line-stolen/
  • Replies 41
hat the hell is an anti car jack button
its so easy to break into a skyline hehe, i locked my keys in mine in a shopping centre i was there for about 3-4 mins breaking in lol first time id done it.. and several people walked past and joined in, i even got some young asian guys to help me and my friends!! no cops showed up or nothing drove off in my car no one said a thing!!
are we saying something about asians?? Cough cough lol just playing..
yeah i did the same thing WITH MY ENGINE RUNNING!!!
being asian and wif a few of my mates there tryin to get into it no one even sussed us out..
took about 5 mins, there more ppl willing to help than stopping to question us if it was our car or not..
if i saw a few guys covered wif tattoos tryin to get into a car it's 000 straight away.. my 2 cents :thumbsup:
Yes for sure. This was one of the first things i looked out for. But rather than disable it(cause i find it useful), i've put like a missile switch cover on it. Also disable the remote boot by pushing the latch down in the boot. Makes it harder for your amps to get flogged. And always always use the clublock. I know sometimes you think its pointless cause everyone says that they can be gotten around and sometimes we just can't be arsed, but when you see your car gone, u will definitely kick yourself.
Oh yeah, and don't EVER fool yourself to think your immobiliser is going to be enough. This is not piece of mind. Even if it was the ultimate unstartable, they will still try, and u will be left with a 1-300 dollars job to fix the damage. Visual deterrents go a long way.
a) I think there are good ones and bad ones.. the good ones work alot better
B) (If you have a good immobiliser/alarm) If you get your regular idiot who thinks they can break a window and force the ignition barrel to start your car a club lock might save you alot of damage.
c) (if you have no alarm) It will slow them down and cause more noise.
(and the down point)
d) (If you have a good immobiliser/alarm) It gives the impression that you are putting trust in the club lock to secure your car... so people might think all they need to do is bust a window, break your lock, and force the ignition when infact its the immobiliser which is secureing your car... so you end up with more damage but your car is still there.
I remember i borrowed my mums car years ago when i was having a clutch redone in my old pulsar. put a club lock on and went into work. came back and relised the key for the club lock was on the key ring with my car... and the spare was in the ash tray of my car.... :Oops: but with a twist and a pull i could lower the clucb lock 1 notch. a few attempts and she was off. 2 minutes work :uhh:
A better way is to put it on backwards, i.e behind the steering wheel, rather than infront, the guts of the clublock should be up against the steering wheel hub, so much tighter fit. If you can force the notches then get rid of it, it is broken. Get one with lock pins(like the ones in gym equipment seats).
I Disabled this switch after some helpful advice from my engine tuner Matt "hitman", apparently this switch is how his skyline was broken into.....
If you cut the brown wire under the door control pannel leading to the switch, you will still have the functionality to lock the passengers door, but not unlock it.
Cheers
Yeah, i always turn the club lock back the front so the barrel faces the dash. The Bast#$ds hit the barrel with a slide hammer, makes it pretty awkward if between wheel and dash.
Also bought a good quality wheel clamp (if Going away or something) "keep-it-clamp -it" are the best, looks pretty bad but the car is still were you left it. Can never be too careful these days!!!!
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
