  • Replies 53
thats why my mate was so shocked, he said gtr700 was 8.2 as a drag car, and this has to be one of the quickest ones around
he only did one run then took off his parachute n left straight way aparently...but i thought more people wouldve seen it
https://www.sau.com.au/forums/topic/68354-807-quarter/#findComment-1267853
yes it is true, for all the people who said 'noway' where you guys there if not the shush. 16th march test and tune.
yea sorry champ but I think there has been some kind of mix up. This car would not be street registered and even if it isnt, I still am skeptical of the time. 8.07 is redicuously fast and I think a car that can run that would have been receiving more than a little publicity. A car that can run that time woud have seen the track numerous times for testing and someone would have let leak about it by now.
Besides all this 8.07 and a street car dont mix.
https://www.sau.com.au/forums/topic/68354-807-quarter/#findComment-1267985
ACTUALLY!!! YOUR ALL WRONG HE COULD HAVE DONE IT!!!! I SAW HIM!
wanna know how? well read on. There one day lived a litte boy called Johnny! He had a fast 32..it ran a 11 but that didnt satisfy little johnny he wanted more. Problem being he didnt have any money. So what he did was, go to willowbank for a test n tune. Little johnny knew from experience that a false start didnt affect your time so the next time he went he false started by 3 seconds, whilst the red light came up noone took notice of this and just stood astounded at the 9.08 little johnny had just run...standing proud little johnny fled the scene in hope that noone had realised what he did. WELL I SAW YOU JOHNNY you lying little biatch...:cheers:
This story may or may not be true!
https://www.sau.com.au/forums/topic/68354-807-quarter/#findComment-1268001
but in all seriousness this is probably what happend....its probably a 10second 32 or something and he got ancy jumped the start by way to much...the clock doesnt stop for false starts and your time still appears on the board..the other person just always wins and it comes up with false start at the bottom of your slip.
https://www.sau.com.au/forums/topic/68354-807-quarter/#findComment-1268004
Your storys are ****ing crap. :D
https://www.sau.com.au/forums/topic/68354-807-quarter/#findComment-1268013
Negative Ghostrider...
Even if you redlight, the ET is still correct... The time starts counting from when you leave the staging lights, regardless of whether the green is on or not...
It's simply someone with farked eyes...
https://www.sau.com.au/forums/topic/68354-807-quarter/#findComment-1268022
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
    • hahah when youtube subscribers are faster than my updates here. Yes some vid from the day is up, here:  Note that as with all track day videos it is boring watching after the bloopers at the start.  The off was a genuine surprise to me, I've literally done a thousand laps around the place and I've never had instability there; basically it rolled into oversteer, slipped, gripped and spat me out. On the way off I mowed down one of the instructor's cones and it sat there all day looking at me with accusing cone eyes as I drove past. 1:13:20 was my fastest lap, and it was in the second session, 3rd lap.  It (or me!) got slower throughout the day as it got hotter.
    • It sounds like you want what the Toyota Landcruisers have for their roof racks. Wanna know what you end up with? Rust holes in the roof, and water everywhere...
    • Discovered today that if I select reverse first and take my foot off the brake, then select drive, the drive indicator light works and so does the tiptronic gear indicator.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Does anyone here have any ideas?   Cheers guys
