Negative Ghostrider...
Even if you redlight, the ET is still correct...  The time starts counting from when you leave the staging lights, regardless of whether the green is on or not...
It's simply someone with farked eyes...
dont ruin my story about little johnny.
  • Replies 53
my mate was out there, and he said a black 32 drove in, they swaped the boot over to one with a parachute attached to it. it then drove up and on the first pass did a time of 9.2. he didnt see any other passes on the night but i think if you run that on your first pass there would be room for imrovement.
Right on, as I said, it was the APC one.
i dont know what it was running or any details of the car besides it was black, ran a 9.2 first run and it drove in and out of the track.
As I said, it was markr34's car (a member on the forums) - drove it to & from the track, thought it did a 9.7 though. Has a built engine with a T51 SPL - should be some quicker times soon.
We have a winner.
That is all.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
