can I suggest that if this 'hiccup' is only happening on cruise (ie. part throttle/light load) then you should look at your O2 sensor. as when running in closed loop your ecu is trying to target a stoich AFR for economy. It does this by reading the value from the 02 sensor, if this sensor is stuffed it won't run right on cruise, but will run fine under full throttle conditions.
Also, as Abo said you cannot use a Z32 with an unmodified ecu. the car may run, but it will run like sh1t.
I never though about the O2, will definately try that. What are they worth do you know??? Also heard a rumour that you can use the falcon ef/ el sensors.... How true is this theory???
Maybe drive to melbourne when the vic guys are having ameet of some sort. It only takes a few minutes to swap over a stock ECU or AFM. I'd hate to see spend money on something that doesn't fix your problem.
Also thanks Abo bob Its a good idea to swap and try before buying, just gota find the time to make a trip down.
I think that is true about the falcon ones.  The information is definitely available somewhere on this forum.  There is a very long thread about o2 sensors so look in there.
Do you know where I can find it here. There is so much info on this site, I wouldn't know where to start???
Anyone confirm the falcon O2 sensor theory???
the o2 sensor wont affect your cars running smoothness or hiccuping
the 02 sensor is used by the ecu to save fuel when the throttle isnt at WOT
so its only used when you dont floor it, the ecu checks this value to lean out the fuel mixture to save fuel. it shouldnt make the car "hiccup". the o2 sensor from the ford falcon works and i have one in my r33, worked with stock ecu and powerfc
the falcon o2 sensor is a generic sensor and its used on a few cars actually.
its just easier to ask your local parts place for a ford au falcon o2 sensor
rather than a skyline one cos then they go what model and what year and they wont have it on your system or give you a o2 sensor that is for the r31 skyline as their computers/database usually only have the r31 as it was aussie delivered
that being said i dont think the o2 sensor is causing your problem. you can unplug it to test that theory if you like, it will just run mega rich and waste fuel. the plug is on the dump pipe just after the turbo heat shield. its a little prong thing that goes into the exhaust pipe. the plug with have 3 wires, just disconnect it
So you don't think its the O2 sensor then???
The car only hiccups on cruise (ie; hardly pushing down on the accelerator or when you start to back off) sometimes it may do it when you slow down to a stop without braking...
The mixtures on the dyno appeared fine (4 runs). Could that just be luck, afm, o2 sensor, ecu or what???
When i drive my car in the morning, it plays up (like the AFM is unplugged), but when i drive it home 6 hours later it's fine. My auto electrision told me my ecu isn't in the best health (it wouldn't let my AC turn on), so would the morning driving be my ECU or AFM? Are R33 and R32 AFM swapible?
hi marcus,
did you sort anything out after our phone convo? let us know how you go
Hey Paul,
Cheers for all your help. I am waiting on a stock BOV to try (in terms of the bov noise) and am waiting on the O2 sensor also to come in.
Will keep you posted on how it goes...
Marcus
no probs, i noticed (when i was looking for stock afms) you were inquiring about a z32 afm, the z32 wont work with the stock ecu unless its been remapped or you have an safc (not sure if you knew or not)
Cheers, but yea the boys told me the same thing earlier. However after our discussion I don't think its afm... Will find out when I try the o2 i guess...
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
