World Record....?
Guest DIRTgarage
In the Dyno shootout comp. yesterday, TWO.06L recorded a mind blowing 627bhp.
which is 467kw. Is this a new World Record for a GTR running 2530 turbos, or for that matter low-mount turbos alltogether. Jim from Croydons is sure it is but we would like to find out for sure. By the way nitrous-oxide running cars do not qualify and must be running on jap pump fuel or equavilent.(we ran VP 103)
https://www.sau.com.au/forums/topic/68548-world-record/
  • Replies 64
Chunky. Not bad for what I heard was a stock bottom end :P
Oh and I doubt that Jap bowser fuel is as oxygenated as the VP gear, how much timing did you end up winding into it?
Good results anyway, time to do some benchpress practice with gearboxes :)
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1270962
Guest two.06l
4% more than what we had?? I think?
don't think we have ever said it's a stock bottom end? We will have different box again for next event, should be better.
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1270985
ill try but im sure it was like 2 yrs ago since ive heard of it
could have been low mount 30's or 28's... cant remember off the top of my head. was almost unbelievable cos u wouldnt think u could low mount those bigger turbos.. but aparently was.
at this stage uve got the record n we will stick to that :P
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1271071
or as a quick reference:
Posted by: Guy R
Here are the results from the low-mount turbos, on mine and Henry's car that we both own!
My car (2.6litre, wild cams)
Max on 2530s - 560bhp
Max on T618Z - 672bhp
Henry's car (2.8litre, mild cams)
Max on 2510s - 554bhp
Max on T517Z - 635bhp (only 1.5bar)
Conclusion, from 2 cars on rollers:
The HKS GT2510/2530 will struggle to get 600bhp.
The Greddy T517Z and T618Z are noticeably bigger, still low-mount and easily capable of flowing 600+ to 700bhp.
The above are facts as tested on a MAHA dyno in England.
Guy
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1271075
Hey now that you mention it....
Phoenix's Power (http://www.phoenixs.co.jp/bigsite/home.html) have got a few near that power figure. From their power rankings:
1) BNR32 - R34 N1 turbos, PowerFC, cams etc : 645.5PS (636.6HP/474.7kw)
2) BNR34 - HKS GT-SS, PowerFC etc : 634.1PS (625.4HP/466.4kw)
Will check out some others.
https://www.sau.com.au/forums/topic/68548-world-record/#findComment-1271084
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
