Just another quick motorsport/performance related post.
My R32 GTR has been fitted with R33 GTR Brembo calipers and the larger 324mm disks front and rear by the cars previous owner (lucky me).
With a set of pads and some good fluid, will these brakes be up to track days? Ive seen a lot of GTR's with what seem like very expensive V8 Supercar brake kits fitted to them, these kits must be very expensive, are they really necessary, or can my setup be made to work well enough?
Thanks.
https://www.sau.com.au/forums/topic/69043-brake-talk/
pads and good fluid should do it i reckon..
although these cars are built for street - they are better than the average street car.
if u are doing serious track work then MAYBE u might wanna consider rotor upgrade...
but if its for fun - why not...
GTR - gran turismo racing.
https://www.sau.com.au/forums/topic/69043-brake-talk/#findComment-1278907
Yes perfectly fine.
Just choose a wise set of brake pads (RB74 from www.racebrakes.com.au for instance - ~$150/front) and don't pretend to try and break any V8SC lap records on the day and you will be fine.
Do 3-4 laps and then just cruise around at 60km/h for a lap and then another 3-4 laps and call it quits for that session so you don't overheat the engine (coils/manifold/fluids etc) too much.
Don't use your handbrake at all on the day, just rest your car on your jack stand or something solid.
https://www.sau.com.au/forums/topic/69043-brake-talk/#findComment-1278975
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
