hey guys i need some help finding a NEW front bar 4 my r33 s2 in tas any help would be good thanks
Any luck in finding a front at all nathn_r33??? If not let me know what ya after as i may be able to help you out :rofl:
Any luck in finding a front at all nathn_r33???  If not let me know what ya after as i may be able to help you out ;)
na not yet. i have found some but nothing that i like to much there just isnt much out there for the r33 s2
Where abouts ya looking m8? I know a few dealers on the mainland that have pretty competitive $$$ range and they have a fair bit in stock. Which part of Tas ya from, North/South?
i think i found one from jds imports. any one had anything to do with them they are in glenorchy.
im from the north east (st helens)
I Just got a 400r bar for series 2 from Carmate.com haven,t fitted as yet
jot it in 5days have a look at their sight
Kerry will look after you at JDS and they can get there hands on a lot, the problem with carmate is that you pay that extra bit for shipping and they do the dogyiest ppackaging job i have ever seen. Hence dings, dents and marks in your new FB and you have to pay for it to get fix as they freight company have nothing to do with it!!!
ok kool thanks for the info i will try jds first as it is not as far to get it here and from what you say they might be better. thanks heaps
Car Artist in Lonnie are ok, they should be able to find you a bar if you know what style you want roughly
You got nay contact details for them champ, are they on the net at all???
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
