$65,000
Priced for a quick sale (lease almost up). Complianced 2001 (with 6,000km on clock).
Currently 47,000km (original dash). Limited modifications and driven by 55 yr old dentist. Never raced or been on drag strip.
Mods:
* Mines ECU (fitted in Japan)
*Blitz Auto Turbo Timer (fitted in Japan)
*Custom SS 3.5" exhaust from standard dump pipe back
*Blitz DSBC Boost Controller
Ideal for someone wanting to start from scratch with an almost "stock" vehicle.
Based in Gladstone, Central Queensland. Genuine buyers only. PM me or email me at [email protected]
https://www.sau.com.au/forums/topic/69100-1999-r34-gtr-v-spec/
Manu
Here are some engine pics. As you can see, basically everything is still stock. You can see though on the left where the boost controller pipes have been fitted.
Yes, I'm prepared to haggle a bit with the price, but certainly won't be giving it away. :(
Regards Alan
  • 3 weeks later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
