Close. It's actually a mid 60's holden....and it's tight fit.
Height is probably not so much of an issue as ic pipework.
Mid 60's, mmmmmm EH perhaps?
I would run a 120 degree bend at the throttle body, that will avoid the cross over pipe behind the radiator. This one has the intercooler pipework running outboard of the top radiator hose. It is more common to run the intercooler pipework inboard of the top radiator hose as it lessens the sharpness of the bend at the RHS subframe.
Hope that is of some help.:P
So when does the factory plenum become a problem then?
If im soon to be running a GT35r on a HKS lowmount manifold with a 45mm ext. gate running 20 psi, would the std plenum still be good to use?
I think (may not be right :P) that it will be like in the region of 530 odd BHP?
*discalimer*- im not here to start a war...peace forever with the std plenum i say :cheers:
Yep.
I'm not entirely convinced thats going to work, but i'll check it out. I'd have to go outboard of the radiator hose because there's virtually no space anywhere in front of the engine (it's so tight that I had to get one of the pulley hubs machined off the harmonic balancer to fit).
Yep.
Yep, the red motor is bit shorter than an RB, the bell housing is a fair bit bigger as well. I drove an EH with an RB30ET in it a few years back. Went real well:cheers:
Ok, this is my problem, its going into a drift spec 180sx, i've moved the engine back into the bulk head to move the weight off the front and behind the axles but not really the main reason for doing this, i've got a front V-mount Greddy intercooler (i.e made room for it).
So basicly because the engine is far back the plenum is crashing into the strut brace and at the very front hiting the bonnet, i've got a S15 front end on the car and the bonnet sits lower then standard ect.
Need to sort somthing out as i don't have the time to make one that works.
now your going to say well get the bonnet to sit higer and make a strut brace that goes around it, but the biggest problem of all its in the way of the brake servo :eek:
as i say don't need it to be any better then the stock one as i know thats good, just not be any worse.
Thanx you
i know the problem you are having here is a pic of my setup it loks like we are both going the same path with the engine build and i was looking for a plenum aswell
my throttle body hits the bonnet to at the moment
but it fits the reason i want to move mine is that i cant fit any desent sized thermos cuz of the pipe work and i want to keep under bonnet and inlet temps down so i dont have to cross infront of the radiator and back over the engine
Thanx you
If you are really seriuous about drifting, an RB in a S13/14/15 chasis is not a smart move. It moves the centre of gravity up too high at the front (that's why it hits on the bonnet) so the change of direction induces excessive roll. Even worse, it moves the polar moment of inertia a long way forward, so maintaining a drift becomes very difficult. I am not a big fan of SR20's, but you really should consider your options.
If you have gone too far down the RB path to turn back, then the RIPS inlet looks to provide the best option for throttle control, which is what you are going ot need. It's not perfect, but if you have painted yourself into a corner you don't have a lot of choices. You will just have to be mindful of the differential tuning requirements of each cylinder.
cheers:
Unfortunately SK I think i'm in this position as well....but i'll still check out your first suggestion. Damn painting myself into corners....
I understand were you coming from SK, and i've had this on my mind from the begining but this is something i really want to do, i had a go in a S13 with a RB25DET conversion and it really did make the front end planted at high speeds (noramly understeer) so i'm more then happy with how it will feel at the end of all this.
The engine is very low tbh, i've had to make a new sump for it as i've retained the stock RS13 crossmember and made very low brakets ect, but its just that bloody intake being so high.
My options were my CA18DET tunned up, or RB20DET tuned up, i hate the bent cam so it was close call between the two.
you do get feed up of changing the bottom ends on the CA :wack:
