i was actualy looking at goin 600cc nismo injectors.. wolf3d (**** that afm off) and yer mods to go along with it
You need a job first warick, removing the AFM isn't always the case!
P.S who's tuning it up here!
Had a wolf before I got the power fc, wouldn't recommend it, as it was send really high coil charge time causing car to misfire constantly at high boost and fry most of the coils that why I got spitfires, also idle and cold start where really bad compared to power fc's but if you have really good tuner might be alright.
nat maybe mind your own business and no ones tuning it up here.. wouldnt let anyone up here touch it no matter wat computer i put in the car ofcourse a trip to bris will be in order by the time i get everything in so yer..
i just have a thing.. i dont like afms :) they can fail... they need cleaning blah blah blah
job meh..
*edit* and if your goin to type my name instead of just waz or wazz or watever.. ITS WARRICK not warick or warwick
blah
I've heard stock injectors are alright under 250 rwkw and 1 bar should be under that without cam and coils. You'd also need a Z32 air flow for more boost anyway, also might be worth looking into 2nd gtr injectors as my 555cc injectors max duty are only about 70%.
Sweet cheers. I have to buy a new turbo anyway, but can't afford to do the clutch, AFM, PFC, injectors and pump, FMIC and GT-RS all in one shot.
Does it sound silly if I get what I can afford (basically everything but the AFM, injectors and pump) and use an R33 actuator on the GT-RS to keep boost right down just to get the car on the road, even though it won't be all that special until I can afford the fuel etc upgrades? As it is at the moment I don't have a running car (other one was written off) so the fact it won't be running anywhere near potential won't bother me.
Reedy - thats because of the actuator that HKS supply with it. As I said before, I I'd like to run an R33 one on it - which is sprung to around 7psi. That way, in theory - the minimum I'd be able to run would now be 7-8psi :P
my understanding of the stock r33 turbo system is the spring is 5psi and the dual stage boost solenoid it uses opens the boost level to 7psi after 4500rpm. is this not the case? my r33 came like this and many others have too and theres an easy way to bypass that as well. with my hks evc turned off im stuck at the spring level which is 5psi
correct me if im wrong i just thought that was how it worked
The least I ever managed to get mine to was 7psi (the R33 electronic boost solenoid raised it to just under 9psi at 4500rpm). Not 100% relevant anyway, I want to know if it'd be safe like this :P
    • Started sifting thru my brakes to decide which ones I will run on Clem   Made me think I should just put them all on Silver...for when brake fade just isn't an option   Should be able to bump rotor up from 343x32 to 348x36 off Supra. Not sure if the Supra annulus is right for the Alcons or APs but trying g to find a used Supra\M4 rotor to test fit The Alcons seem to gain 1-2mm clearance which all helps
    • So car is getting a few mods to the cage and some jacking points welded in Meantime Ol Silver gets a new gearbox and shiny clutch.  Old Box is being set aside for Clem
    • Probably speedometer itself if the odometer is ticking. If the needle is stuck from a bit of grease or something that can cause it to stay at 0. Or a cracked solder joint in the speedometer can do it too.
    • Thanks Fella’s   to take this off topic and to elaborate a bit more. I have an rb25/30 going into a r32 GTST.. expected to make around 600-700hp. Would you?   A) R34 GTT box   B) CD00#?  I’ve seen a few posts about the CD swap and sounds fairly involved with making it fit etc but if it’s worth the work then I’ll go that way
    • Lower at the hubs. Funny I forgot to mention that part. Do this pull here I turned the camera off too soon but the graph shows a drop at the top and that was because the pipe from the turbo blew off. The tuner said we could’ve made possibly another 15 whp. He also added if I switched to ethanol we could up the boost some more as well. I was comfortable capping it at the most of 20 pounds. Turns out the turbo pipe just needed a new worm clamp. Got home replaced that then did a third gear pull from 3k to 7200 rpm and the power was great to the top. I just got an ecu mounting bracket from IEE that I need to try and get everything to fit well. It’s a PITA to get the harness and ecu fit properly behind that kick plate
