1994 Nissan Skyline R33 GTts, Mods Inc
EAST BEAR GTR front bar and grille & Gen GTR clear indicators
Type M side sirts and rear pods
Gen GTR Rear wing
Bishop Blue paint (includes engine bay, doors and boot)
Tinted Windows
UAS custom airbox,
Custom dash (silver with blue pearl, also guages were lighter and ashtray were)
Carbon fibre steering wheel
Recaro Seats front and rear
Rays Volk Challenge Wheels (white with silver inserts) 18x8 and 18x9 rear with new falken tyres
Tein HR coil-overs supension
Nismo Mini locker
BeeR full exchust 3.5 inch Turbo back & Jast Jap front pipe
Nismo clear side indicators
ENGINE MODS:
Full rebult motor with
Shot and pined rods
New Nissan pistons
O-ringed
machined crank
porter head/maifold and inlet, (Flow bench 276hp)
Hybird cooler (600x300x70)
S/S cooler pipes
Hi-flow fuel pump
Apexi turbo timer (pen type)
Samota Air filter
Standerd Turbo/injectors (V/G condition)
Custom Blue Airbox and rocket covers
Brand New 5puc button clutch with GTR pressure plate
86K on the Clock and less then a 3k after rebuild
Also Power FC - Yet to be installed
Will not separate anything, no time wasters pls,
$25500neg VIC reg til Nov 05
189kws on 10psi,
Call 0400261099 or PM
https://www.sau.com.au/forums/topic/69234-r33-electric-blue-skyline/
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
