Well well well its time for some headaches.
The car was running but when i started it sounded like a V8 car like it was misfiring. Suddenly it stopped 1 hour later and was souding like an RB after 1 hour of driving.
Then a few days later after driving it it was having problems starting it.. slowly slowly getting worse on starting it so i had to get it push started to get it running.
I was running low on fuel b4 it started playing up? Not sure if this will effect it.
I instantly thought my plugs where dead since they looks nasty and where very old. I replaced the plugs just then with BCP6E plugs NGK (x6) and the car still wont start.
The coil pack plugs are all cracked and half missing plastic on them. Why isnt the car starting? I havnt tried to push start it yet as i dont see it making a differnce? Is it the plugs really? but its still not starting? If anyone knows what happend to this beutiful 5spd RB20DET Cefiro please let me know.
John Cambell
https://www.sau.com.au/forums/topic/69355-car-not-starting-now-rb20det/
its too csotly too fix, you can buy another.
Its on the front of your CAM belt cover... the round silver thing.
thats not 100% what it is though, just a likely choice.
a workshop you need to go to i think
What are they worth to buy from wreckers ( used ).
Do R33 ,R34 ones fit? GTR also?
Thanks
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
