48 hour permits???
Guest GR33DyMANGO
hi guys. well my cars finally ready to be picked up from the compliance workshop:)
now i have to go and get a 48 hr permit so i can drive the car home. so what im wondering is whether i can just drive my car around anywhere for 48 hrs or only to specified places?
whats the deal with these permits? any help is much appreciated.
thank.
justin:)
https://www.sau.com.au/forums/topic/6945-48-hour-permits/
I thought you were only allowed to go to places to get work done to the car, but you can bullshit can't you?
"Yes officer I'm on my way to get the car tuned, honest."
GR33DyMANGO caught doing 210km/hr in a 60 zone at midnight Saturday night.
See'ya
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-102693
When you ring up they ask you what movements you need to make, home - workshop - pits - home etc.
You cant drive at night, all road rules apply, only you can drive the car and a few other things they tell you when you phone transport.
I think I needed to get these bloody things 4 or 5 times when I bought my car in:
docks to home
home to pick up comp. plates then home again
home to get comp. work done
comp. workshop to pits then home
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-102705
gr33dy, is yours the white R33 down at Global?
twas down there today getting my plate stamped on, your car looks nice n clean.
I then went to the pits and failed :) rear tint is too dark and the radius rod bush is leaking oil.. which is what a replaced when i busted up the front from an incident a while back but the piece is obviously faulty, it was second hand so i cant complain.
a new one goes on tonight, aswell as the tint off tomorrow and all should be cool.. *gulp*
Shaun
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-102921
Originally posted by Pva_Glue
cruising doesnt make you cool... it's how you drive your skyline make you cool.
does that make sense?
cheers
Joe
Quote: - From Instructor @ MC Motorsport on PVA
"That guy is an accident waiting to happen!......"
:) :) :):D:):rofl: :rofl: :rofl: :rofl: :rofl:
So....how does this cool thing work?
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-103001
Shaun
Hi Radium,
Nope, the white one with the GTR body kit is mine.. Got it detailed for $100, if anyone is interested. It was so filthy when it got off the boat .. I think it would have been better had I clean it after I got the car over the pit, but I just couldn't look at a dirty white car. :)
Bye
Richard.
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-103014
thank.
justin:)
Hey Justin,
I got the temp 48 hr permit last weekend and drove it around ... Went passed two or three police cars in town but no one pulled me over. Probably because I was moving like a snail :) ..
Bye
Richard.
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-103016
I got pulled over on the way from picking the car up from the trucking yard to home. The guy wasn't worried about the permit ... he didn't like how the front bar was sitting inside the car!
I also drove around the city without plates before I had rego. Cops drove past and didn't care :)
Maybe they see it all the time round the licensing centre.
https://www.sau.com.au/forums/topic/6945-48-hour-permits/#findComment-103129
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
