I was looking at lowering my r33 gtst with some king springs.....
i can get the "lows" (35mm) but i wanted a bit lower...i was told that king springs recommend not putting the "super low" (50mm) springs on because it would be too low, causing the car to be hitting its bump stops?? is this true?
the wheels are 235/40/18
anyone have a better idea....coil overs would be nice but are a bit out of my budget. i thought about 40-50mm lower would be nice without being too extreme and dumb. :D
https://www.sau.com.au/forums/topic/69728-king-springs-too-low/
A 50mm drop will effect the camber; you will need adjustable camber arms to correct. I dont think it will hit the bump stops. Also, the standard shocks don't like being so low and will wear out quickly. Had the super lows on my car and it handled terribly, probably because the geometry was all off. Switched to lows and the ride is much better. I suggest that if you're going to use super lows you will need to invest in additional suspension bits to get the suspension geometry right. Also have 238/18's and there's heaps of space under the gaurds, no problems with rubbing.
yeah i didn't think 50mm's lower would be much of a problem....will have to look in to getting new shocks as well then. Also should get the camber adjusted. Anyone know of something other than whiteline kits? I know they are good, i just want another option to choose from. cheers
well the shocks are not specific to whiteline, apparently they are off the shelf items from bilstein, so you can probably get them cheaper direct.. as for springs, you could also try king springs, but the whiteline springs are not too expensive (around 350) anyway..
there are a lot of options in terms of springs, but i believe that bilsteins are best suited for an r33 in our conditions...
and yes you will need a camber kit if you want to drop it heaps, most suspension places will be able to sell you these...
thanks, well i guess i will be getting that rear camber kit. :) do you really need to adjust the front if lowering 50mm? or do you think it would be ok?
I can get the king springs cheap, so thats what i'll be getting. just have to decide on low or super low. The shocks i will shop around but i will look into the bilsteins ones. cheers
i just measured from the centre of the wheel to the edge of the gaurd, rear is 370mm and the front is 365. i'm thinking now that 50mm lower will be a bit to much for everyday driving. any comments?
i think you should check what the lowest point of the car is before you go buying super lows, who cares if you get them cheap, go out on the weekend and get dicked over because they are too low.
i think its 100mm or 110mm you can have at the lowest point. Most cars out there are illegal when you look at them, just make sure urs isnt, just to be safe :)
or not to be picked on, (AS MUCH) you do after all drive an import :)
good luck
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
