OK, result is in guys. I ran a 12,466@108,20mph with 1,860foot time on TEIN RA, street tyres that wore out ( Phillip Island track day ), Heavy duty clutch.
I did the 12,4 pass with second gear bog down so in my third attemp, i dumped it at 7,5k. There was no bog down, as i slamed it into 2nd, rev was still at 6k which is good where when it bog down before it went to 4,3k, car make noise but didnt go anywhere i then realise the freaking clutch is slipping.
Next time i'll go out try to dip it into the flat 12 or hopefully high 11 with proper GTR rims ( as i still running on 235 front and 265 back ), good tyres, clutch and see how i go. I belive my transfer case still confuse even down the end of the terminal as i look at the tougre gauge i had around 30% power to the front where it should NOT. It should have 100% to rear.
Anyway i only own my gtr for 2,3 months so there is a lot to learn about it but i'm can tell u now i love the launch on the GTR. ****ing awesome.
  • Replies 96
West, 30% is what it should read giving it full throttle.
i know my mates GTR reads like 30% while hes going full throttle 180km/h+if he launches hard
Like said i'm still have a lot to learn about the GTR, i thought it suppose to give 100% to the rear after it gained traction so u can have more power but anyway its all good.
Forgot to mention i only run 14psi. :P
Nice! ;)
I want to buy a GTR R32 soon.. but i mite stick with my sil80 i just bought :P
']someone correct me if i'm wrong on this...but dont GTR's work based on lateral G forces and not based on traction?
they work on both g forces and traction. sensors detect if rear wheels are rotating faster than front and feed power into front accordingly. thats why gtr's need wheel sizes exactly the same otherwise power will be fed into front wheels cause computer thinks wheels are slipping
You can have thinner tyres on the front.. but you cant have differnt size wheels and profile tyres.
You can have thinner, different wheel size and different profile, the thing that matters is the rotating diamiter has to be exactly the same, otherwise the ATTESA will think the wheels are slipping and apply torque to the front. The best way to get exactly the same rotating diamiter is to have the exact same size wheel/tyres on the car..
West: Well don on the 12.4! Thats the same as i ran when i went to the drags, but i was running @112mph i think... but i couldn't get off the line, axle tramp everywhere.
thats what i said about the tyres man :cheers:..
The GTR race team that was eventually banned from racing way back when had an interesting method for getting off the line. They had a delay switch fitted to the front wheel drive so that the rear wheels would spin and let the engine get to it's 6000rpm with the drive train 100% locked in. Then the ATTESA would kick in and load up the front.
With this method there is no wear on the clutch and the drive train had an easy start. I would imagine the transfer-box would heat up a bit, hence, the transfer case cooler.
You said "...but you cant have differnt size wheels and profile tyres."
You can have different sized wheels and profile tyres if you like, but the rolling diam needs to be the same.
but if you change the tyre profiles then you will change the rolling diameter :confused:
profile depends on the width of the tyre. Also you could have a difference sized wheel, which means you'd need a bigger profile etc....
    • Hi everyone, I'm about to complete my first single turbo conversion on my R32 GTR and I thought I would post the step by steps that I will be following. I will list the parts I have / the parts I will be buying. I will be redoing this guide after I have completed the conversion. Parts list: - 3576 turbo 0.82 v-band (coolant and oil)  - v-band top mount turbo manifold - 50mm wastegate - manifold copper gasket - titanium manifold stud kit - turbosmart 3 port boost solenoid - link can lambda kit (wideband) - link ECU - radium 12AN push in valve cover fittings (pair) - hi octane catch can - 3.5inch downpipe - screamer pipe - pipe from turbo to intercooler - intake pipe setup - power steering relocation kit - oil drain block off plate - coolant and oil lines Now onto the step by step guide (please add / correct me if there's anything I missed: 1. remove fluids, twin turbo pipes, pod filters and afm's 2. remove the factory coolant hardlines from the hot side. 3. remove heat shields  4. remove the downpipe 5. remove turbos and manifolds 6. remove factory manifold studs 7. clean whatever mess you have made 8. install power steering relocation kit 9. install new manifold studs 10. install new turbo manifold with gasket 11. install new wastegate with screamer pipe 12. install new turbo  13. install new coolant and oil lines  14. install rear oil drain block off plate 15. stop and appreciate that you now have a single turbo in your GTR 16. wipe away tears of joy and install downpipe 17. install the wideband sensor into downpipe 18.install pipe to connect turbo to intercooler 19 .remove stock boost solenoid  20. install new boost solenoid 21.  install intake setup 22. setup the rest of the can lambda kit with the ecu  23. refill fluids and hope for the best 24. ask forums for help with issues 25. fix issues 26. drive your single turbo swapped r32 GTR into the sunset. Doneeeeeeeeeee. Now I know this isn't detailed at all but I will be doing that when the conversion is done. I will be posting pics and any helpful details i can and ill make sure to fit in as much information as I can. If there's anything I should know before i do this PLEASE let me know. Stay tuned for what's next. Thanks...
    • I have wasted too much time on this, more than I am willing to admit. I hope someone can set the record straight for me.  I want to replace my Nismo (non GT pro, non GT) standard 2 way in my R33 GTST with a 1.5 way... Ideally I want to get an ATS 1.5 way Carbon LSD, but I don't want to reuse my 29 spline 5x1 axle stubs, and new 30 spline 5x1's are impossible to get a hold of ($$$), and I don't want to drop the cash on going to 6x1 stubs and axles ATM. Which leads me to the Nismo GT Pro 38420-RSS15-B5 or RSS20, as they come with new axle stubs meant for the diff, and is "Convertible" from a 2 way or 1.5 way to "Other ways", but that is where I am stuck as the documentation is a bit all over the place.  To sum up what I have found I believe the all the Nismo GT Pro PN's are convertible from 2 way, 1.5 way, and 1 way; but Nismo sells 2 skus (2 & 1.5) so people do not have to disassemble to convert it.  I found this thread on 350z but it left the question unanswered. https://my350z.com/forum/engine-and-drivetrain/620032-nismo-gt-pro-lsd-1-5-vs-2-way-and-torque.html  Essentially the way I think it all works out is like follows...  2 way  1 way  and 1.5 way would be the center pinion shaft in the 1 way block, but with the with the center flipped 180*. So the ramped side of the pinion would face the 1 way gate and act like a ramp.    I can only get my hands on the 2 way in the states, and I am not trying to get stuffed on tariffs by ordering from Japan or anywhere else. I want to confirm that if I get the 2 way I can convert it to the 1.5.
    • Hi everyone, I have purchased my first GTR and I want to do a single turbo conversion to it. I've been doing as much research as i can and there are a few things that I can find and need to know. I need to run a coolant feed, coolant return, oil feed and oil return for my turbo setup. Here's what I know so far: On the hot side of the rb26 there is coolant feed, oil feed and oil return. Coolant return will be going around the front of the engine to where the thermostat is located. I will need to block off the rear oil return port. I will be running a turbosmart boost solenoid so any of the factory boost stuff wont be needed. Now onto what I don't know: 1. What do I do with the coolant / vacuum hardlines that run around the back of the motor?. 2. What do I block off or loop or move or remove?. I will be running the OEM intake manifold. 3. Is there anything in particular I need to buy for the cold side of the rb26?. I already have the intercooler and pipes sorted. If you have any pictures or information it would be appreciated. Thanks....
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
