  • Replies 61
nah it's all booked, so as long as we have 12 people we will be fine. I am hoping we will get 24 racers, so we can split up into 2 separate Grand Prixs and take turns in qualifying and racing etc. I spoke with Greg and he was in, but he said Leroy was only a possible on account of his wife :cheers: Will catch up with you soon Matty for a few drinks.
Oh add a +1 for me. I'll most likely be bringing a mate along with his 180SX.
Anyone else going to the SVD Dyno Day @ Tilbrooks in the morning? Figure I might go check it out, not sure if I'll run since I had one just recently, but I could use it as an excuse to play with my boost controller some more... :)
since its all booked and there seems to be more than enough of people doing plus the fact that im a maybe, you guys/girls have fun.
Poor excuse mate, I count 22, doubtless people WILL bail on the day, and failing that you can at least come to the meet/diner earlier on to say hello.
Cummon yah bum you missed the Port Elliot cruise! :)
yep the final venue is Richmond.
We will be meeting at an undisclosed North-Eastern place for early dinner at 5:30pm then mini-cruise to Richmond. Those on the other side of town can just meet us there. For anyone that wants the info please PM me and I'll send you the meeting place and restaurant/cafe details.
Sorry I can't make the grand prix - I didn't realise that Adelaide United are playing on the same night and I've already bought a ticket. I'm keen to meet for the dinner and mini-cruise.
you have to come Duc - we really need 24 people for it to work properly. Come either way, it will be fun.
Yep no worries Matt, Leroy or Greg are of course welcome to come with me - unless Chops is coming with me, then you'll have to squeeze Greg in the back of your car :)
i didnt look at the first post to see the update, it just seemed that alot of people was posting they would come and the fact that they would bring xxxx people along made me think that there was enough. Either way, my gf just read the post and insisted that she also wanted to go - shes never been go-karting, so put me down as 2.
Good work Duc, your missus has the right idea, see you and her on Sat! :)
We don't cruise very often anymore due to the massive police presence and resultant diminished fun etc.
Especially now it's winter you will see many of the Skylines from this site home in their garages.
But keep an eye on these forums, as cruises do happen from time to time.
    • Assuming the current ECU is stock, it might be worth getting hold of a nissan data scan cable. It could be as simple as voltage at the ECU
    • You need to test for spark when it matters - ie cranking. Kill the fuel supply, pull a plug and earth it, set up a camera and go crank. The spark needs to be consistent, every other turn of the engine. Not some sputtering of occasional spark. The reason I say this is because spinning the CAS in the air is not the same as spinning it installed, and if there is a bearing problem in it, the disk might work differently in the air than in the engine. You won't want to try to set the timing unless you know the spark is happening right.  Also, reconsider running the R35 coils against the stock ECU. They like a different amount of dwell cf the originals. It's not massive, you can actually run them, but it is better if you can adjust the dwell (which you can with Nistune in the stocker, or with an aftermarket ECU). Besides any of that - when you had the multimeter out, have you got power where it needs to be, earth where it needs to be (and when, in the case of igniter triggers), etc?
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
