what colour is the smoke???
if its black, you could have a busted intercooler hose, it will be running super rich and go like a shot cat (after it dies), id check that first..pull the intercooler pipes out and inspect them and the rubber hoses.
i had a similar problem and it turned out to be the 90' rubber hose under neath the air filter.
cheers
Linton
the plugs will be as black as Samuel L Jackson if a cooler pipe is busted, check the plugs for damage, make sure you know which cylinder each plug came from, could be a coil pack problem also. if the plugs are all uniform in colour but then theres one thats different, that will be it. try putting that plug + its coilpack and run it, see if it continues to play up, remove it and check the colour again. if its the same, seperate the 2, put a different plug with that coilpack, that will tell you if its the plug or coils.
depends on what blow off valve he has andrejp.. he hasnt said what mods it has, might have a hks one or something which dont leak.
it all depends on colour of smoke, if its white, or bluish, then could be a busted piston ring or worse.
post up the mods and conditions before it happened.
cheers
Linton
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
