Blow off Valves - Apexi , Blitz, Greddy, HKS, Sard
is the HKS SSQV the same as the BOV on need4speed underground 2? lol serz....
n i already got this *hole* in my standard piping with a rubber cap on it,would that be where an aftermarket BOV goes?
  • Replies 52
hahaha my bro reckons it sounds similar but it doesnt have the high pitched sound... i dont play it and havent heard the ssqv in person... but yea youd attach the flange to the hole then bolt the bov on
Okay so if I can find the right kind of adaptor I can just weld it on, and the aftermarket BOV will bolt straight onto it?
Can anyone please clarify, plumback is where the air is recirculated, whereas atmo is where the air is just vented out? I was reading that plumback didn't offer any performance gain, is that true?
HKS34R: You'd have to check the GFB / turbosmart sites but I think they do sell adaptors for some other branded BOVs.
Lithius: Correct about the adaptor. It's probably more correct to say that plumbback doesn't offer any performance loss, as that's what the factory one is. An atmo BOV is louder and may cause stalling at low rpm if you haven't tuned your car for it.
just a quick question, i have an rb20det in a silvia, if i was to get the greddy type rs for rb20det/r32 gtst, does it bolt straight on where the factory bov is? Or do i have to get a flange welded onto my cooler pipes and do it that way?
im not sure if they sell type rs kits
but one im getting through the GB requires a flange
Contact BD4s. They helped me out with advice for a flange for my 34. Advan performance may also help you out with the Greddy stuff.
Has this closed yet or am i too late and can someone recommend the best BOV for a HR32 GTS-t (all stock running gear) and will i need an adapter kit as well?
:rofl:
hey just a quick update - supplier confirmed that he recieved the transfer this morning and that he would notify me once it has been shipped
waiting to get the current ones in .. has taken a bit longer than expected.. should be in by this friday provided this one goes all good then i should be doing another
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
