Import & Performance Car Theft on the North Shore - Warning
Hey guys, car theft is rampant at the moment on the north shore with chatswood and lane cove being *known* hot spots.
Please be careful.
On Thursday November 28th at 4am one of my friends in St Ives caught 4 guys under his bonnet attempting to steal his black R33 GTST from outside his front door. the following night a 200sx was stolen from the same street. They had ripped out his alarm from the engine bay but hadnt got into the cabin.
The sunday before another friend in Lane Cove has his 180sx stolen from up his driveway. Fortunately the 180 has been found in Macquarie park missing only small parts like bov etc.
Chatswood police have mentioned that performance car theft on the north shore is VERY high at the moment
Be careful guys its getting pretty bad again.
Originally posted by Timmy G
I thought you could always use "reasonable" force if you're threatened?  (Self defence?)
I need a tazer, are they legal?
if YOU are threatened, not your property.
tazer's are illegal.
self-defence is not a complete defence, only partial. meaning: you kill someone you don't get done for murder, but manslaughter. up to the judge whether he believes you or not. you may even get off.
however, doesn't automatically mean you are free from liability...
a judge will always frown upon you 'defending' your property, such as a car, rather than your 'persons,' as property can always be replaced and its not a danger to yourself.
