A mate of mine wants to buy my old R32 GTR Engine.
Ive heard that an RB25 Gearbox bolts up to a GTR Engine & Also bolts up to an SR20.
So does this mean that his SR20 Box will bolt up to the GTR Engine??
Anyone know about this?
Thanx
Should do, maybe with some mod.
The S14 Gearbox is quite strong. Much nicer than the S15 one. A number of people have changed thier S15 boxes to the S14, although you loose the gear, you gain strength.
Dunno how it would go with the added torque of an RB26 though. But good boxes for thier money
It would be a waste of time due to the cost and time involved in making an adapter as they do not bolt staright up just as the RB25 box does not bolt up to the SR as it also needs an adapter. It wouldn't last long behind a RB26 anyway. Just use a RB25 5 speed.
Thanks for the insight guys. Just wondering what the best option was. He is thinking about the RB26 In an S14 200SX. Adapter plates and so forth would be a piece of piss but I figured that it wouldn't be strong enough.
Cheers,
Rhys
So what do S14 drivers upgrade to when they get big power behind the SR20s??? I thought they kept the same box... so I would have thought it would have been fine unless he went insane on the engine and took it past what you could do to an SR.
People with big power SR's quite often run a RB25DET box with a modified bellhousing.
A GTR gearbox with the transfer case "removed" will fit into the S14 tunnel with only slight mods. :rofl:
The RB25 box is basically that. As far as I am aware, the RB25 box has the same internals as the GTR box, just without the transfer case...
Jeff.
yeah, people charge upto $300 less ive found for a GTR box as opposed to an RB25 one.
that said, shopping around can net you either at a cheap price if you are patient.
I laneded my 25 box for $1300 and that included the whole tailshaft etc
Maybe different in NZ.. I can pickup a R32 GTR box for under $1000. A 25T box is $1500-$2000.
The box I am running in my Silvia was a RB26 box that had been in an accident and had a hole in the transfer case... so I got it even cheaper.
Just had to cut the side off it and weld it up.
Sounds like it would be cheaper to import an RB26 box from NZ than to buy local.
SR20 bellhousing WILL NOT fit RB26. The SR boxes start to have difficulty around 260rwkw, depending on how you drive.
RB25 boxes do fit on to S14, with modified tailshaft, shifter and differnet cross member (sr20 auto cross member from memory). Also, you may have to modify the tunnel slightly.
D1 garage would be able to provide the bits as they do full convedrsions, ie, rb gearbox to SR20.
Thanks for the info.
We can do all the mods and conversions ourselves. I was just wondering whether or not is would bolt straight up or if it required modding. We will settle with a RB25 box just wondering if it was worth running the SR for a bit but I don't think it will be worth it.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
