Just wondering if anyone can tell me the differences between the GTS-4 and the GT-R. Mainly concerned about the AWD system, are they both the same or are their many differences. Also just any other basic differences minus the engine for obvious reasons.
Just curious as will be purchasing a R32 soon enough and as i already have a R33 GT-R engine, would it be cheaper to place the engine into a GTS-4?
Any help would be appreciated.
-KRILLN
https://www.sau.com.au/forums/topic/70661-gts-4-vs-gt-r/
hi
gtr has different diff ratios - so may have to change the rear diff to match the gtrs front diff ratio to the gts-4 rear ratio- unless you use gts-4s front diff also.
gtr has mechanical rear lsd, gts 4 has viscous
gtr has different ratios in gearbox and i think also has heavier duty gears in box, tho box looks same on outside.
4wd system is the same - variable torque split to front wheels
chassis is the same
suspension takes same parts although spring rates may be different
wiring is very similar - see gtr workshop manual covers gtr and gts-4
gtr has thicker front discs and has directionally vented rotors, gts-4 has same rotors left and right - pads are same for each tho.
gtr has better seats, gives slightly more rear leg room in back
gtr is a 4 seater, gts-4 5 seater if they have small bums
gts 4 has same driveshafts, swaybars,
gtr has of course aluminium bonnet and front guards
both have abs brakes
gtr has super hicas 4ws as opposed to normal hicas on gts-4.
gtr ( more aggressive to cope with the extra power that gtr has??) may have a diff rate that 4wd comes on-?? not sure tho
prob a few others, but these are the main ones
hope that helps
Stephen
https://www.sau.com.au/forums/topic/70661-gts-4-vs-gt-r/#findComment-1303846
