  • Replies 61
hey guys,
I should have my set sanded this w/e. haven't had much time this last week with changing jobs n all, and i've been crook which doesn't help matters any.
Let me know which type you guys would prefer...if you want ones that just stick on, i can put them together pretty quickly, and it will only use half as much fibreglass, so i can sell them cheaper ;) If anyone wants the stick on type, i should be able to put a set together this weekend (unless I keel over from being sick ;) ).
Once i have my bolt on set trimmed to fit, i'll see how they go with the bonnet...but i can't see there being any issues. They will bolt on at the back, and I'll probably be sticking them at the front so thieving little s**ts can't get their fingers up underneath to rip them off.
**PM** me with what you guys are expecting to pay, and i'll try and work my price around that :) I'll also work out how much i'll need to charge to cover my costs ;)
I trial fitted the eyelids to the car last night after trimming them, I need to shave a little off the face of the pass side one to even things up.
They fit and the bonnet closes normally. The little black rubber things on the bonnet were originally hitting the eyelids but I trimmed it (edit: by "it" i mean the eyelids, not the black things) back and now fits with no issues :P
Also tried to "steal" them with the bonnet closed and they weren't going anywhere :D
All that's left to do is:
*sand the pass side eyelid
*make brackets to fit
*paint
Once i have this set completely finished I'll put a post in the F/S section :D
To give me an idea of demand, please PM me or post here and let me know what you guys want:
*stick-on (will just cover the top & face of the headlight), or
*bolt in (covers face and entire top of headlight)
:P
Michael
Man, i'm interested too if you're going to start making more lol. Been after eyelids since i bought my 32, makes it look so much "Tuffer"!
A bit off the topic, but how do you's get that little pic of your cars in ur info thing? I've taken pics of my car with my fone, but cant work out how to put it up there!?
Let me know how you go with the eyelids i'm VERY keen.
Michael is thinking of gettin' a GTR so it isn't goint be cheap ;)
:rofl:
will trade for GTR Parts ;) hahaha if everyone donates something (a caliper, a radiator, an engine, etc ) I should be able to build a GTR by 2010 :wizard:
but seriously, I'm going to make 2 or 3 types.
1- Stick-on ones for maybe 50-60ish (to be confirmed) - these will just cover the face, an dif someone was so inclined may be able to be ripped off :(
2 - Stick on that are a bit bigger and will be hard to steal because of the way it is moulded around the headlight,
3 - And the 3rd type which will bolt at the back, and can be stuck at the front (so they don't rattle around and are a bit more secure :) This is the type i have made and basically ready to be painted.
As per one of my previous posts, i tried to "steal" the 3rd type from my car with the bonnet closed and it was impossible. Also I couldn't get enough leverage to break or snap them off because they are moulded so closely to the headlight :D
If no-one wants the cheapies then please let me know and i'll focus my efforts on what you all want :) Even better if you could email me which type you'd prefer @ Midnite_Garage at hotmail dot com it will be easier for me to keep track of what people want. I'll let you know set prices for type 2 and 3 sometime next week when i have pics.
:cheers:
Michael
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
