Wheels are Desmond Marquis Promoda, the style is Riga Master, the model is Evo - made in Russia!
These wheels are sought after & extremely popular in Japan as they are a rare lightweight circuit wheel.
Some info @ http://www.wheelspecs.com/specs/wheelbrands/40
The tyres have 70% tread (only 3 months old) Nankang 255/40/17 all around.
I have been offered $1800 via a local wheel importer so if anyone would like to take them in the interim it means that I don't have to wait till mid May for the funds.
Wheels are perfect, no marks or damage.
In Sydney, Marko 0404 884 876 (pics below)
https://www.sau.com.au/forums/topic/70867-unmarked-17-x-9-wheels-with-70-tyres/
guys,
i am negotiable with price now as the local wheel importer has lost his customer who was originally keen on the wheels...
what are they worth? feedback?
marko
0404 884 876
my highest offer thus far is $1500 hence i will now sell them for this price (or higher naturally)
reminder that these wheels are not damaged or scratched at all, perfect condition with near new tyres & extremely lightweight!
just take a closer look at the images...
i am selling them as i have 3 sets of wheels for my gtr :)
marko
0404 884 876
I just received another pm for more info on the wheels
offset: +18
attached images to this msg with stickers shown on inside of the wheels & confirmed wheel dimensions
marko
0404 884 876
no offence but looking at your rims i would have bought them for $600 if i were you - you totally missed a bargain!
your comment is the classic line of "paying nothing for something"
if only all of us had the same luck :rofl:
these wheels are worth the money your asking in fact if i were in sydney id seriously consider them, why do tyre kickers have to say stuff in the parts section too!!
is there an easy way to get them to brisbane?? idea on cost to ship them??
hi "blur",
thank you for your genuine post:
to ship interstate is approx $100-$150 to (brisbane/vic)...this is via a large well known freight service 'tnt', 1 that believes in safe handling
i will find out prices tomorrow & post them
what can we say about tyre kickers, mate there is always a clown in the class.
marko.
0404 884 876
hi guys,
for those interested, freight costs below:
syd to bris $90
syd to melb $90
syd to south aust $90
syd to western aust $120
door to door service delivery
marko
0404 884 876
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
