Im about to do a rebuild on my RB25 which I have been using for sprints and mostly drifing.
I want to upgrade the oil pump and was concidering an N1 Nismo pump.
I can order it through a mate who runs the spare parts section at my local Nissan dealer if I can give him the part number.
Am I doing the right thing?
Can anyone tell me the part No?
What would you use?
https://www.sau.com.au/forums/topic/70917-oil-pump/
I have yet to find an RB water pump or oil pump that doesn't fit all RB's (RB20/25/26/30).
In my opinion N1 pumps are a waste of money, they have no more flow than a standard pump. Just a stronger spring in the pressure relief valve. Save yourself ~$300 and buy a $2 spring upgrade for your standard pump, same result.
:P
https://www.sau.com.au/forums/topic/70917-oil-pump/#findComment-1308521
What's a worthy upgrade for an early RB26 in terms of new oil pump?
I'd heard that the R33 N1 was the go due to it 'catching' on the crank better?
Ya prolly getting confused between the cranks of the R32 and R33 GTRs. The R33 crank end extends further and engages into the oil pump socket better. This can be rectified on the R32s by adding an extension adaptor (fairly easy to machine up).
https://www.sau.com.au/forums/topic/70917-oil-pump/#findComment-1322400
    • ok so if i wanted to go 18's i would go for 8's  in front 30+ or 32+ off set at front and the back 9 would be ok? what offset should i aim for.. then can i do some  hunting for wheel rim choices..
