nik.. i ran 2 15 sec pass's for ya man ... where was ur daewoo lol
ahh wasnt a bad nite... got a lot of problems goin on with mine. nothing a few more hours wont fix.. had my B&M shifter cable al farked up.. wasnt selecting 2nd but when it did it droped it back into 1st few mili seconds later.. still managed an 11.7 with 1st gear and part of 2nd hahahah ohhh and i did a 12 flat with the crank angle sensor goin out on me half track lol rolled it in for a 12.1 i think it was.. ... that wasnt really fun tho...
although was wrapped with my 60 footers.... 1.53 was my best.. ( gotta love the transbreak. **** gives u a buzz when u launch at 18PSI lol )
mite fix the shifter up and turn the power up on it next time.( wouldnt mind a shift lite as well.. gets kind of hard looking down at ur dash... wanna work out all my kinks b4 i chuck in some c16 and let it rip out 35psi :-)
seen a few of ur skylines running tho.. r31 nismo... didnt mind ur car.. its moved top end... nic3e screamer pipe btw :-) there was a black R33.. that seemed like it had a bit of power there... spewing i couldnt race when it started getting cold..... nik.. i didnt see ur daewoo tho.. im pretty pissed at u..
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
